JammyDodger
I have for sale my Mesa Boogie Mark V:35 Head. This is a used amp. It has been in my home studio for the past year. It is a 2017 model (I believe). New power tubes installed in November of 2021
Please see pictures provided and the notes below for condition and wear. It will be packed with care to be shipped to your door! If you have any questions about this, please let me know and I'll be happy to help!
Condition Notes:
- Condition: 9/10
- Any wear of note: There's one or two very light scuffs on the sides that are hard to photograph. But overall in really amazing shape. In perfect working order and sounding incredible. Comes with original cover, footswitch, footswitch cable and IEC cable.
My thoughts on the amp...
- The Mark V series is just incredible. Mesa Boogie packs so many extremely usable features in such a small package while keeping it very simple and easy to use. And they sound amazing. They're really the total package. They have everything from a great sounding and usable XLR direct out to 3 different selectable wattages on each channel to a designated footswitchable solo boost and more. It's really the ultimate amp that's geared for anything!
Price is $1700.00 Shipped in the CONUS
From Mesa Boogie:
AMPLIFIER FEATURES
Amp Type - Tube
Chassis Material - Aluminum
Rectifier Type - Silicon Diodes
Preamp Tubes - 6x Mesa 12AX7
Power Amp Tubes - 4x Mesa EL-84
Maintenance Free Fixed Bias - Yes
Wattage(s) Quick Reference - 10, 25 or 35 Watts - Channel Assignable - See Power Amp Details for more information
Power Amp Details (Class & Wattage) - Mesa's Patented Multi-Watt™ (Patent 7,602,927) Power Amp, featuring Dyna-Watt™ technology, providing three power levels and two wiring configurations (Pentode/Triode) via two 10/25/35 Watt Power Switches: Choose from 2 power tubes operating in Class A/B Triode for lush harmonics and a sweet, liquid feel at lower volumes, producing 10 Watts or; 2 or 4 tubes operating in Mesa's proprietary Dyna-Watt™ Class A/B Pentode for maximum power, punch and clarity, producing 25 or 35 Watts respectively
Convection or Fan Cooling - Fan Cooled
Number of Footswitchable Channels (or Modes) - Two Channels
Number of Style Modes - Six
Number of Style Modes Per Channel - Three
Types of Style Modes Per Channel - Ch. 1 = Clean, Fat or Crunch Ch. 2 = Mark IIC+â„¢, Mark IVâ„¢ or Extreme
Channel Controls - Each Channel features Independent 3-Position Style Mode Switch, 10/25/35 Watt Multi-Watt™ Switch, Gain, Treble, Mid/Boost* (Ch 1), Mid (Ch 2), Bass, Presence, Reverb (back panel), Master, Footswitchable Channel Independant Solo and Graphic EQ Assignment Switch (On, Off or Footswitchable) - *The Mid/Boost Control on Channel 1 doubles as a standard Mid Control when set between 0 to 5 and turns into a Variable Gain Boost when set from 5 to 10
Graphic EQ and/or Contour - Selectable 5-Band Graphic EQ (Footswitchable, Channel Assignable or Off)
Reverb / Effects & Bypass Options - All-Tube, Long-Tank Spring Reverb with Independent Channel Controls
Effects Loop & Bypass Options - Fully Buffered Series FX Loop
Global Solo Level Control & Bypassable Options - Footswitchable, Channel Independent Solo Controls
Speaker Outputs - One 8 Ohm and Two 4 Ohm
Cabinet Simulation - Direct Live/Recording Output - Built-in Mesa CabClone™ Cab Simulator with Internal Amp Load & Headphone Output - Featuring Closed Back, Open Back & Vintage Cabinet Simulations, Speaker On/Off and Ground Lift Switches
Headphone Output - Yes (see Cabinet Simulation for more information)
QUICK OVERVIEW
Build Location - Hand-Wired In Petaluma, CA with the World's Finest Materials
Wattage - Multi-Watt™ 10, 25 or 35 (Channel Assignable)
Power Tube Type - 4x Mesa EL84
Channels & Modes - 2 Channels / 6 Modes
Mode Voicings / Styles - Ch. 1 = Clean, Fat or Crunch Ch. 2 = Mark IIC+™, Mark IV™ or Extreme
Graphic EQ / Reverb / FX / Solo - Graphic EQ, Reverb, FX Loop & Ch. Independent Solo
Footswitchable Functions - Ch. 1/2, EQ, Solo Ch 1 & Solo Ch 2
Weight - 27 Lbs.
Dimensions - 9 1/8" H x 18 3/4" W x 10 7/8" D
Condition Notes:
- Condition: 9/10
From Mesa Boogie:
AMPLIFIER FEATURES
Amp Type - Tube
QUICK OVERVIEW
Weight - 27 Lbs.
