First split cathode amps question ....
Discussion in 'Let's Talk Vintage' started by Joshabr1, Jun 11, 2021.
  1. Joshabr1
    Joshabr1 Well-Known Member
    Sep 2, 2013
    1,424
    678
    Ky
    So when the lead amps started evolving .. when the split cathode amps came in to being was the .68uf cap on v2?? Or did it arrive later ??
  2. South Park
    3,526
    3,080
    I looked at the schematic and did not see one on v2 . The 2204 has that cap on v1
  3. Joshabr1
    Sep 2, 2013
    1,424
    678
    Ky
    The schematic from Marshall in 1970 had it there. I don’t know what schematic you are referring to. Every split cathode Marshall and master volume have the .68 on v1.
  4. william vogel
    Dec 18, 2016
    612
    635
    From what I understand, in 1968 the split cathode on V1 appeared with 820 ohm/.68. The 4.7nF was added to vol 1. V2a got bypassed with the .68 and the tonestack changed to the 33k/560pF on super lead. The 50 watt lead model probably is the same.
  5. Joshabr1
    Sep 2, 2013
    1,424
    678
    Ky
    So really the only time you don’t see it there on lead models is after the move to 100k in the neg feedback ??
    neikeel likes this.
  6. stickyfinger
    Nov 11, 2010
    780
    376
    I had this all figured out at one point but have forgotten the variations timeline but in a nut shell for lad spec...
    Some amps did not have a V2.68 in 71, some with 47k maybe a few with 100k feedback and some variations of the 4 or 8 tap or maybe even at the speaker jacks. 71 all over the place.
    72 was no .68uf v2, 100k 4ohm tap feedback.
    Mid 73 same as 72 with .68uf on presence and 4k7. (no scratchy pot)
    Later 70s (76?) Same as mid 73. Lower volts
    neikeel and Joshabr1 like this.
  7. Joshabr1
    Sep 2, 2013
    1,424
    678
    Ky
    I’m more concerned with the 68-9 era amps
  8. william vogel
    Dec 18, 2016
    612
    635
    68-69 should have the cap.
    Joshabr1 likes this.
  9. Ivan H
    Ivan H Member
    Jan 17, 2021
    24
    44
    The JMP (model 1987/1959) split cathode amps first appeared in late '67, with an 820r/.68uf on both V1b & V2a. This continued through '68, however sometime early in '69 the 100 watt model 1959 was changed to have the now common 2k7/.68uf on V1b (still 820r/.68uf V2a), the 50 watt model 1987 continued with the 820r/.68uf V1b, not exactly sure for how long. Hope this helps. Cheers
    Joshabr1 and Travis398 like this.
  10. TAZIN
    TAZIN Well-Known Member
    Mar 18, 2013
    644
    287
    From what I can tell it looks like the 100w Super Lead received the split-cathode arrangement first starting around late 1967. These would be the SL/10xxx amps which had the gray colored RS 0.68uF bypass caps on V1B and V2A. These early examples don't appear to have had the volume pot bypass cap (5nF) but did have the 47K NFB resistor. The 50w lead amps (model 1987) seem to have received the split-cathode setup in February - March of 1968 and once again I don't believe they had the volume pot bypass cap. In April - May 1868 you see the addition of the 5nF volume pot cap for the 50w lead.
    Joshabr1 and neikeel like this.
  11. neikeel
    6,017
    4,741
    I echo what Tazin said, although I have never seen one without a cap on vol 1 pot at all. Even my early 67 45/100.(EL34 version) had a 100pF cap there.
  12. TAZIN
    Mar 18, 2013
    644
    287
    I forgot about your amp. I know the early 'Lead' amps had the 100pF but the examples I had on file either didn't have a cap or it was removed.
  13. stickyfinger
    Nov 11, 2010
    780
    376
    Have you ever seen a 50 watt with the gray rs .68uf bypass caps? I have a pair for a build but I don't build 100 waters!
  14. TAZIN
    Mar 18, 2013
    644
    287
    Yes.
    stickyfinger likes this.
  15. stickyfinger
    Nov 11, 2010
    780
    376
    You wouldn't happen to have photo you could share?
  16. TAZIN
    Mar 18, 2013
    644
    287
    Not the greatest photo but it was the easiest to grab.
    Joshabr1 and stickyfinger like this.
