stickyfinger
- Joined
- Nov 11, 2010
- Messages
- 859
- Reaction score
- 453
Is that how you run the eq? Presence on 10 and TMB on 0?
Thank You Again Neikeel! You have saved the day again! Some of my research has told me to heat the screw up first with a soldering iron, but do you happen to know of any methods to get it moving? I almost stripped it trying to remove it with force.The screw has a dab of loctite!
Gold tadpole - the stuff that goes round the head cab front panel is available from Marshall and their dealers but it is a bit paler than the original. The Marshall supplied gold string is very green but the correct diameter. The North Coast Music stuff is the right colour but slightly slimmer.
Afraid you will need acetone to soak and soften or heat.Thank You Again Neikeel! You have saved the day again! Some of my research has told me to heat the screw up first with a soldering iron, but do you happen to know of any methods to get it moving? I almost stripped it trying to remove it with force.
Funnily enough marshall have finally sorted out their ‘green’ string, I bought some last month, it’s pretty close to the vintage stuff colour wise now!The screw has a dab of loctite!
