Gene Ballzz
More of a "theoretical" question than anything else. Without electrically "elevating" the filament center tap, where is the best place to connect this "center tap" of what seems to be the "dirtiest" unfiltered AC circuit to the rest of the "0" volt system?
At first glance, it may seem appropriate to simply tie it to the chassis, but that makes that circuit dependent on the chassis as an operational conductor, potentially putting voltage and current on the chassis.
Conventional wisdom suggests connecting this "center tap" directly to the same point as the HT "center tap." It seems there must be a better method? Is "elevation" the only real solution here? The downside I see there is that we are simply "re-introducing" that dirty AC connection to the later stages of the amplification process, paticularly in a cathode bias configuration?
Just Askin'?
Gene
Just Askin'?
Gene
