Hi, I'm trying to figure out what tremolo arm to get for my US made strat, see image. The more i read about it the more confused i get. Any help is most welcome! Cheers, Mike
The tremolo block has thread size you have to start with that . Find the arm or replace the block with arm that fits . Not much more you can do
I dont know if this will help but my CS strat has a push in bar, my USA one has a screw in bar. They otherwise look the same. I will try and take a pic of the different ends when I get home.
Depends on the year and the model. That picture of the bridge is not the current model. You can email Fender support and they should be able to help, if the bridge is original to the guitar. I'm guessing it's a push in, if the guitar is recent.
Everything else is original as far as I can see, so I guess the bridge is original as well. According to the serial: Your guitar was made at the Corona Plant (Fender), USA in 1993 - 1994 Production Number: 129681 Do you think this is "recent"? It feels like threads in the hole if i scratch the inside with an A-string. But maybe it is like that also on the push in?
If it were me, I would buy Fender 099-2310-100 Standard Stratocaster Tremolo Arm. It should fit. 6mm thread seems to be the consensus. And it can be had for less than $10.
Thanks all! Reverb did not deliver to my location, so i ended up ordering this one from Amazon, which hopefully is correct.
2 point with a properly lubed and cut nut and locking tuners are pretty stable. I save divebombing and flutters for floyds but they are fine for most normal vibrato effects as long as theyre set up correctly.
That says it's for the Mexican Standard -- the threads won't fit your American Standard. Back then, there was the "Standard Strat" (made in Mexico) and the "American Standard Strat". You need a trem arm specifically labeled for the American Standard.
