Fattening up a DSL40c lead tone?
Discussion in 'Marshall Amps' started by ledvedder, Jun 10, 2021.
  1. ledvedder
    ledvedder Active Member
    Jan 13, 2011
    527
    204
    New Jersey
    I love the rhythm tones I'm getting out of my DSL40c. I have a Creamback 65 speaker in it. But when I play a lead, the sound just doesn't seem to be fat enough. What are some of the tricks you guys use for your lead tones? I do have an EQ in the loop with the mids boosted a bit and the level a bit. I've tried hitting it with a tube screamer, but that just seems to thin it out even more.
  2. Jethro Rocker
    9,749
    14,067
    What mode? Channel 2 OD 1??
  3. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    2,099
    2,188
    Calgary, Canada
    Try the opposite way,
    Dial it in for your lead tone on the amp with mids and volume, then use the EQ in the loop to cut that down for rhythm tones.
    This will also give you a greater dynamic interaction with the amp and react to your volume knob on your guitar better.
  4. ledvedder
    Jan 13, 2011
    527
    204
    New Jersey
    Channel 2 od1 mostly.
  5. Jethro Rocker
    9,749
    14,067
    When i had a 40C I did the c19 clip it made it less thin. Dunno if that will help you.
    Also, I only used ODs with 2 band EQ, I always find ones with tone 9nly yo be thin. Every one of them. So a Timmy, Bad Monkey etc amd can dial in some lows when running that channel w a boost.
  6. FracStrat
    FracStrat Well-Known Member Gold Supporting Member
    Jan 22, 2020
    767
    2,280
    Water Side of WA State
  7. StrummerJoe
    StrummerJoe Well-Known Member
    May 3, 2021
    588
    1,243
    I use the volume and tone controls on my guitar to switch between rythm & lead. Also fattens up a thin sound if needed, but I eq at the amp for that.
    I think @Dmann suggestion would probably work for you better @ledvedder
  8. rick16v
    rick16v Well-Known Member
    Mar 13, 2014
    3,227
    2,645
    Swindon, UK
    More volume to get the power tubes working working. Then dial back guitar vol (and/ or tone) for rhythm sounds.
  9. 5stringsdown
    5stringsdown Member
    Apr 10, 2020
    64
    98
    I highly recommend the Scumback H 65.....more bottom smoother top......seriously a world of difference!
    Kim Lucky Day and StrummerJoe like this.
  10. 5stringsdown
    5stringsdown Member
    Apr 10, 2020
    64
    98
    Much nicer difference than using a pedal.
    StrummerJoe likes this.
  11. AdrianDSL
    AdrianDSL Active Member
    Nov 11, 2020
    113
    195
    Melbourne, the place to be. FINED!
    WGS Veteran 30 maybe?
  12. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,438
    2,614
    Does the DSL40CR reflect improvements from the DSL40C?
    I have not played the newer ones equipped with the G12M 65 Creamback, but heard that was an improvement.
    If the DSL40C reverb was not so meh, it probably would help fatten up some things.
    Also, (and probably an attribute) there are two designs for back panels. They are baffled differently.
  13. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,175
    2,016
    CR is a much fatter sound - arguably too fat on OD2. Once you get up to a decent volume it's more balanced. Dunno what they did to the C to make the CR.
  14. ledvedder
    Jan 13, 2011
    527
    204
    New Jersey
    I have a Creamback 75 and a Veteran 30. Do you think I should try one of those in it? Problem is, the Vet 30 is only 8 ohm, so that doesn't leave me the option of running my 16 ohm ectension cab if I need it.
  15. JCMDOUG
    JCMDOUG Well-Known Member Gold Supporting Member
    Mar 1, 2015
    532
    541
    where its cold
    Clip C19 and Bad Monkey over drive like Jethro Rocker suggested. The problem for me on my DSLs was one eq for two channels. I would switch channels for a volume boost and the tone was just not what I wanted for a lead sound and then they added a gain stage. I have found that more gain on the preamp side and individual notes thin out. I moved on to Marshall JVMs and JMDs.
  16. Mitchell Pearrow
    13,788
    26,352
    Put an EQ in the loop, that has probably already been mentioned, but it will do the trick.
    houseofrock likes this.
  17. ledvedder
    Jan 13, 2011
    527
    204
    New Jersey
    I use an EQ in the loop for soloing. I mentioned that in my OP
  18. Mitchell Pearrow
    13,788
    26,352
    Sorry I didn’t remember that.
    :cheers::fever:
    junk notes and ledvedder like this.
  19. AdrianDSL
    Nov 11, 2020
    113
    195
    Dunno about the Creamback 75, but by all means try the Vet30. Just curious, how did you dial the treble and presence?
  20. ledvedder
    Jan 13, 2011
    527
    204
    New Jersey
    Treble around 11/12 o'clock, presence around 9/10 o'clock.
