Extension cabinet question
Discussion in 'Cabinets & Speakers' started by Kim Lucky Day, Feb 6, 2021.
  1. Kim Lucky Day
    Kim Lucky Day Well-Known Member Gold Supporting Member
    Aug 22, 2018
    342
    865
    I'm looking to add an extension cabinet for my JMP2104. On the back panel there are two speaker jacks. The amp has one 16 ohm G12H Greenback and one 16 ohm G12M Blackback wired to an 8 ohm load.
    I have a line on Marshall 1936 loaded with two 16 ohm Eminence Tonkers. I'll assume for now these are wired for an 8 Ohm load.
    First of all, if I plug an extension cabinet into the other speaker jack, will it turn off the speakers in the amp combo? Secondly, if it doesn't, I would assume I need to turn the impwdence selector to 4 ohms (assuming there is a 4 ohm option?). Am I missing anything here?
  2. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    962
    986
    You can use both jacks at the same time -- that won't cut off the combo speakers.
    Yes, set the amp for 4 ohms when using an 8 ohm cab along with your combo's speakers.
    (The cab with two 16 ohm speakers is either 8 or 32 ohms, so probably 8. But if it had a previous owner do check that the speakers are in parallel, not series -- previous owners do crazy things sometimes.)
    Kim Lucky Day likes this.
