Evh 5150 Od Or Be Od ?
Discussion in 'The Tone Zone' started by Sickriverlespaul, Oct 10, 2016.
  1. Sickriverlespaul
    Sickriverlespaul Active Member
    Dec 14, 2015
    222
    71
    Opinions about a good overdrive for a JVM 205h. Thanks
  2. dreyn77
    dreyn77 Well-Known Member
    Feb 18, 2012
    12,559
    2,859
    The way I view the 5150 overdrive pedal is for use with a JMP amp and the EVH guitar and the EVH cab.
    If you want some different sounds from your JVM, Gibson is in the business to sell more guitars instead of pedals, so, just get another model Gibson guitar and you'll be happy. :)
    I don't think the EVH pedal and other brand guitars is a good idea. Once you know how custom the EVH guitar actually is, then you wouldn't go buy a JVM to play with it, cause those guitar pickups, need the EVH pedal to make their EVH tone.
    Good luck!
  3. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,595
    4,019
    C-137
    Neither of them really excel at pushing an already driven amp.
    There's a crap ton of clean boosting OD's out there on the market that do it better.
    Those two pedals were designed for a really clean amp as a platform to do their thing.
    Which is mimic the dirt channel of the respective amps they are named after.
    Dmann likes this.
  4. Ed Hunter
    Ed Hunter Well-Known Member
    Apr 16, 2012
    1,489
    657
    I owuld not use either of those two for that purpose. those two are best for being the main source of gain.
    You are better off with a tube screamer type pedal for a JVM
  5. HOT TUBES 70
    Oct 13, 2008
    11,256
    5,770
    I know a guy who could hook you up with a really nice OD .... you'd love it !!
    lol
    Coronado and dslman like this.
  6. dslman
    dslman Well-Known Member
    Apr 15, 2012
    3,042
    1,494
    I view both as distortion pedals, suited for a clean amp/channel.
  7. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    4,114
    3,579
    Dallas
    I have the BE and if you wanted to use it with the JVM, I would recommend using it with the clean channel (or turn your gain way, way down). I have used it with my JVM1h through a 4x12 on the clean channel and it sounds great. I wouldn't attempt the pedal with the amps gain as it would just be over the top fuzz and hiss. On my JCM800, you can add just a tad of volume with the BE - any more than that would be too much. With my JMP, it sounds amazing. DSL on the green channel (classic), its great. I would have to agree that its better for clean amps/channels, or if you turn the gain way down on your amp. The BE has an internal gain 3 way switch - I keep mine in the middle position. You might try switching it to its lowest setting?
  8. HeHasTheJazzHands
    HeHasTheJazzHands Well-Known Member
    Nov 4, 2011
    8,548
    4,984
    Louisiana
    Have you tried it in the FX loop? I'm curious as to how it sounds completely uncolored by a preamp.
  9. pedecamp
    16,631
    15,426
    Serious? You need an OD pedal for a JVM? 2 channels with 3 modes each, its got everything you need built in no?
  10. HeHasTheJazzHands
    Nov 4, 2011
    8,548
    4,984
    Louisiana
    And unless you're going for a super-duper chuggy/djent tone, it doesn't even need a clean boost. It's a tight and bright amp on it's own.
