Eq in the effects loop
Discussion in 'The Tone Zone' started by chromeboy, Aug 12, 2020.
  1. chromeboy
    chromeboy Well-Known Member
    Jan 25, 2010
    607
    311
    San Bruno,CA
    I was just thinking about adding a boss 7bamd eq on my pedalboard. I've heard that the best place to put it would be in the effects loop. I used an eq maybe 20 years ago but don't remember running it in the loop. So here is my question for you guys. I am already running my chorus and my delay in the loop so if I was to add an eq, would I put it before the chorus and delay or after in the loop and why?
    I figured you guys would know.
    Thanks.
    dptone5 likes this.
  2. jstich
    jstich Well-Known Member
    Dec 18, 2016
    556
    396
    I usually put my eq after my dirt/drive box which is usually a stomper for me.
  3. Trumpet Rider
    Trumpet Rider Well-Known Member
    Nov 8, 2016
    2,018
    3,671
    I have my EQ dead last in line in the loop. It just makes sense to me to put EQ after everything else so that it has the final word on the overall tone.
  4. The Dose of Harmony
    The Dose of Harmony Well-Known Member
    Nov 21, 2014
    599
    643
    Ok!!
    you have to experiment , I have found that in my application the Eq pedal goes first on my FX loop and be prepare you will be able to shape a lot !
    I have a delay , chorus and reverb and and i can a affect the whole chain just bit just by boosting or cutting a just a little i would avoid doing extremes on a eq pedal!
    I found this video very usefull
    https://www.bing.com/videos/search?...559EC30A160C728E087C559&view=detail&FORM=VIRE
  5. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,373
    4,250
    Pennsylvania
    I have the Boss EQ last in my loop. Works terrific as a solo boost and tone shaper. The Boss can be noisy. I have the Monte Allums modded GE-7. Whisper quiet.
    if you play with your amp cranked, the volume boost will be less noticeable.
  6. The Dose of Harmony
    Nov 21, 2014
    599
    643
    can you tell more about that mod on the eq?
    dptone5 likes this.
  7. WellBurnTheSky
    Mar 23, 2019
    769
    1,797
    I use one (Boss GE-7 and now the Source Audio Programmable EQ on my main board), and put it early in the FX loop. I use it as a lead volume boost plus some tone shaping (shaving off some lows and top end and boosting mids a tad).
    My rationale behind that is, I want chorus/delay/reverb to effect a "finished" tone, so all tone shaping is done before hitting these effects.
    Also, specifically for delay/reverb tails, I want them to "follow" the boost: if I hit a note then turn on the EQ, delay tails will be at the volume they were before I hit the volume boost, while if the volume boost was after the delay when I turn the EQ delay trails would jump up in volume, which I don't want. Plus trails would also be effected by EQ changes and sound different.
    So yeah, EQ > delay (and reverb, but I don't use reverb in my guitar rig) for me.
  8. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,267
    1,881
    Massachusetts, USA
    There's no right or wrong answer to this. Experiment and do whatever makes your ears happy.
    Do you want to EQ your chorus and delay tone? Put it after them.
    Do you want to add chorus and delay to your EQ-shaped amp tone? Put it before them.
    Sustainium likes this.
  9. Filipe Soares
    Mar 8, 2019
    1,519
    2,643
    you can also change the OPAMPS in your GE7 for a quieter operation. I did it in mine and works GREAT. the only downside is battery consumption, but I'm hooked on a AC adapter anyway.
    I have a GE7 in my loop and it is GREAT for tone shaping!
  10. The Dose of Harmony
    Nov 21, 2014
    599
    643
    Man you just put in words exactly how i do it too!
  11. ricksdisconnected
    Aug 11, 2019
    3,864
    5,732
    BINGO.
  12. Vesperado
    Vesperado Member
    May 24, 2011
    93
    25
    Albuquerque, NM USA
    Cutting noise on an EQ is quite simple, run it off a battery or an isolated power supply which is grounded well. Doesn't hurt to reflow your solder contacts to get rid of any inherent noise. If it clips too much, open it up and check the opamp datasheet and the polarized cap ratings. If you can run the pedal at the highest safe voltage you will get more headroom, which translates to less clipping. I have some which do fine at 15V. I haven't tried running it in the loop yet, I usually just run the Biyang (4x 4558D) or the Yamaha (single 4559) strait into the front as a boost pedal (9V) unless I need to cut some annoying frequency somewhere before the amp, then its max voltage (15V) to avoid any clipping/coloring. If your particular EQ has low-rated caps but the opamp(s) can handle a higher voltage, perhaps changing out the caps for higher rated ones will provide for some additional headroom. A thought.
  13. mad5066
    mad5066 Well-Known Member
    Jan 16, 2010
    190
    269
    There's no right or wrong way technically, it's just a matter of what you're looking for. If you don't want your delay or reverb or modulation effects altered by the eq put the eq before them. If you do want to have them eq'd as well then put it last. I would recommend try both, experiment, and see what works best for you.
  14. dptone5
    Jan 31, 2010
    5,373
    4,250
    Pennsylvania
    I really don't know the technical aspects of the mod, but here is a link. The second mod is the one I got for my GE-7. It really did make an amazing difference. Good luck!
    https://www.monteallums.com/pedal_mods_GE7.html
  15. ricksdisconnected
    Aug 11, 2019
    3,864
    5,732
  16. dptone5
    Jan 31, 2010
    5,373
    4,250
    Pennsylvania
    Hey Rick. I didn't do the mod myself. I sent my GE-7 directly to Monte Allums and he modded it for me.
    ricksdisconnected likes this.
  17. Micky
    Apr 29, 2010
    21,017
    17,644
    Vermont
    I have a GE-7 in my FX loop on both my pedalboards
  18. ricksdisconnected
    Aug 11, 2019
    3,864
    5,732
    was it expensive?
    dptone5 likes this.
  19. Barfly
    Barfly Well-Known Member
    May 6, 2012
    1,539
    1,764
    NYC, NY
    I have a "Sniper" modded GE-7 in the loop. Modded to shut it the heck up. Works nice. I got it modded by someone eon some forum years ago. I honestly can't remember but he called his "company" sniper. I think his ex wife wanted a piece of the pie or something and he stopped modding.
  20. Matthews Guitars
    2,484
    3,561
    I've been running an Alesis DEQ-230 digital 1/3 octave (31 band) equalizer in my loop for years. Before using this model EQ, I used other 31 band EQs in the loop.
    It's a precision tone shaping tool that if used properly can be used to tweak your tone to absolute perfection.
    Look at all the Bradshaw racks used by all the 80s hair metal players. They always had two or three 1/3 octave graphic EQs in the rack. That was their tone shaping tool
    that gave them their distinctive sounds. The EQ is every bit as important to the tone as all the other effects combined.
    dptone5 and ricksdisconnected like this.
