Dumb question..
Discussion in 'Cabinets & Speakers' started by Marcomel79, Sep 20, 2021.
  1. Marcomel79
    Marcomel79 Well-Known Member
    May 3, 2021
    475
    535
    Oslo
    Hey Marshall folks, i thought i would start a thread to see how many insults i can get for asking a stupid question, so here it is: i have two 16 ohm speaker and i would like to try them with an amp that only has a 16ohm tap. Will a combination of series/parallel wiring keep the load at 16ohm? I know it works with four speakers....
    fitz288 and SkyMonkey like this.
  2. SkyMonkey
    3,710
    5,203
    No.
    Sorry.
    There is a gizmo the can sit between the amp and speaker cabs, but I have forgotten its name.
    Marcomel79 likes this.
  3. fitz288
    Apr 7, 2020
    3,637
    8,949
    rahndahbaht dah 'Burgh
    Re-amp.
    My BadCat takes a single input from any of 4/8/16 from the amp, and doesn't care what speakers you use.
    Old Punker, SkyMonkey and Marcomel79 like this.
  4. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,749
    1,330
    UK
    What is the amp? Most 100W valve amps can tolerate a 1 step mismatch, so if you wired the speakers in series (=32 Ohm) it should be OK....
    Jethro Rocker and Marcomel79 like this.
  5. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    1,109
    1,297
    Weber Z-Matcher. Lets you match just about any imaginable combination of amp and speaker impedances. When I had one it seemed to not color the sound in any way.
    Two 16 ohm speakers can be wired for 8 ohms in parallel or 32 ohms in series. Those are the only possible options.
    Series/parallel (and parallel/series) requires at least 3 speakers, but 4 is much more common so we'll talk about that.
    Let's say you have four 16 ohm speakers. You connect speaker 1 in series to speaker 2 for 32 ohms, connect speaker 3 in series to speaker 4 for 32 ohms, then connect the two pairs together in parallel for a total load of 16 ohms.
    Or you connect speaker 1 in parallel to speaker 2 for 8 ohms, connect speaker 3 in parallel to speaker 4 for 8 ohms, then connect the two pairs together in series for a total load of 16 ohms.
    What amp do you have? 16 ohm only is very uncommon.
    DirtySteve, SkyMonkey and Marcomel79 like this.
  6. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    Its a Marshall DSL5. It only has a 16ohm output. But i know that if you have four 16ohm speakers wired in a combination of series/parallel the final load stays 16ohm. Is that not possible with two speakers?
  7. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    Its a Marshall DSL5. I also have a jmp clone but the dsl is more for night practice as it has a MV...
  8. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,254
    2,190
    No, that is not possible with two 16 Ohm speakers. Either you double or halve the impedance - you cannot attach both without changing it (parallel vs series). Any cheap attenuator will allow you to attach a load to which the amp is agnostic - however, the sound quality doesn't get better. 32 Ohms would probably be OK on the amp, I wouldn't try 8, though.
  9. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    Yeah i guess ill try wiring them in series and see what happens... wont be playing loud anyway...
  10. anitoli
    10,261
    14,808
    Not possible with two 16's you would need two 8's in series.
  11. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    I guess it wont hurt wiring them in series...
  12. fitz288
    Apr 7, 2020
    3,637
    8,949
    Dumb question for your dumb question:
    If the internal Ten-30 is 16ohm, and you can connect an external extension of 16 ohm, is it using both and putting a 8 ohm load on the OT?
    If so, you should be able to disconnect the Ten-30 and rig up two external 16 ohms.
  13. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    The speaker for the amp is connected externally with a speaker cable. Theres no internal connection... if i understood your question correctly...
    fitz288 likes this.
  14. fitz288
    Apr 7, 2020
    3,637
    8,949
    Not exactly plug and play, but you can unplug the internal at the speaker and rewire for another external, basically using the combo as a head.
    But if the external jack is a switching jack that shuts off the internal, never mind.
  15. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    Btw the way, im building a 2x12 cabinet for the plexi clone (18W) and i have a greenback (waiting for my second one in the mail) and today i connected the ten30 with the greenback and it sounded killer.... i can only imagine with two GB'...
    fitz288 likes this.
  16. fitz288
    Apr 7, 2020
    3,637
    8,949
    So both speakers work when the green back was plugged in?
    That would mean the amp will take an 8 ohm load (2 ~ 16's in parallel).
  17. Marcomel79
    May 3, 2021
    475
    535
    Oslo
    Sorry, that was through the mini plexi! Poor wording!
  18. PelliX
    Jun 16, 2020
    1,254
    2,190
    It's not switching - it's the fact that it only has one output jack, namely 16 Ohm. Afaik DSL's do not have switching jacks for speakers, at least I've never seen them.
  19. LPMarshall hack
    Nov 18, 2009
    11,689
    12,972
    San Diego, CA
    Hope this isnt too much of a derail...but will this device allow you to connect your Marshall to say...one 16 ohm 4x12 cab to another 8 ohm 2x12?
  20. fitz288
    Apr 7, 2020
    3,637
    8,949
    So when an external 16 ohm is plugged in, and the internal is still on, the amp is doing what with the 2 16 ohm loads?
