Dsl40cr Upgradeable To 100hr?
Discussion in 'Marshall Amps' started by kkelly9, Mar 5, 2019.
  1. kkelly9
    kkelly9 New Member
    Feb 15, 2019
    2
    5
    Saw a teardown video and basically the DSL40CR and the 100HR use the same mainboard but the 40CR is is missing the 4th set of tubes. I don't have access to a 100HR to do a full comparison myself.
    Has anybody ever looked at this closer and is it possible to populate the DSL40CR with the missing components to make it 100W?
  2. Mitchell Pearrow
    15,299
    30,410
    Not sure on that, but welcome to the forum brother! Cheers Mitch
    stringtree likes this.
  3. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,380
    Wa State
    Even if you could I cant see it being cost effective …… if you were lucky enough to change out the stuff ( top secret schematics aside ) … one slip and the traces on the board are toast …… everything is wave soldered and microscopic …… go buy 3 DSL100Hs for the same $
    JMHO ……YMMV
  4. Micky
    Apr 29, 2010
    21,154
    17,902
    Vermont
    You'd need to add all the necessary components, change the PT and OT and then probably change a few other components.
    Cheaper to buy a 100W...
  5. kkelly9
    kkelly9 New Member
    Feb 15, 2019
    2
    5
    LOL ... Where are the $300 100H's ?!?
  6. Mitchell Pearrow
    15,299
    30,410
    Better question where are the 300$ dsl40c’s? The lowest I see them is 450$, and that’s not very often, but then again I am not looking for one either! Cheers Mitch
    Jon C, steveb63 and stringtree like this.
  7. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    16,792
    20,315
    Taintville
    Even if its possible, why? Just buy a 100 W DSL. If you want a 100 W combo then have a combo cab made for around 350.00 from Sourmash or Mojotone to pop it in.
  8. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    6,616
    7,872
    Montreal
    Isn't there a product out there called a " Torpedo " or something....I think it's called,a re amper or something which can convert your 40 watts to 100 watts?
    BP
  9. anitoli
    10,262
    14,813
    The OP is definitely going against the grain, he wants more watts not less.
    steveb63 and Mitchell Pearrow like this.
  10. Jethro Rocker
    10,128
    15,349
    Yep, a Bad Cat Unleash.
    I have to mirror the above. it's more than adding a couple tubes as mentioned. PT, OT and likely some other components all on a microscopicly detailed PCB. Not to mention at least 100 watts of speaker if one is keeping it as a combo.
    With a reamper you get an attenuator plus a digital 2 channel 100 watt amp that uses the power signal from the tube amp.
    Mitchell Pearrow and BanditPanda like this.
  11. BanditPanda
    Oct 19, 2015
    6,616
    7,872
    Montreal
    Yessir. Thank you Jet !
    That's the ticket for our OP and does so much more.
    BP
  12. Jr Deluxe
    Jr Deluxe Well-Known Member
    Sep 12, 2017
    274
    274
    Ive railed against modding marshalls in other threads. In this case i think he should do it. I want to see what happens.
    steveb63 likes this.
  13. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    496
    1,007
    Az USA
    I didn't give a "like", because I'm not sure I like the idea.............. but the resulting thread would be entertaining.
    Jon C likes this.
