DSL40CR bright cap?
Discussion in 'The Workbench' started by tmingle, Nov 27, 2021.
  1. tmingle
    tmingle Well-Known Member
    Jan 24, 2008
    461
    484
    Mifflintown, Pa.
    Does the 40CR have a bright cap installed on either channel?
    FracStrat likes this.
  2. gregr
    gregr Well-Known Member
    Jul 30, 2014
    766
    851
    Classic yes (two separate values). Red no.
    My unsolicited opinion:
    Clean cap is just right.
    Crunch is a smidge too small.
    Ultra 1 and 2 would benefit from 220pF.
  3. FracStrat
    FracStrat Well-Known Member Gold Supporting Member
    Jan 22, 2020
    1,062
    3,363
    Water Side of WA State
    Greg, Is C74 ready to receive should one decide to drop something in there ?
  4. gregr
    Jul 30, 2014
    766
    851
    It says it’s not fitted so it’s should be all ready to go.
    Full disclosure:
    I don’t own this amp but I have played one. I do have a JCM2k DSL100 and with the same bright cap the behavior of the gain control will be the same. I use OD1 and like it on the aggressive side but I don’t use a whole lot of gain. I use an OD pedal to boost into saturation.
    Bill T likes this.
  5. LCW
    LCW Well-Known Member
    Jan 18, 2017
    454
    888
    Play louder. :p
    gregr likes this.
  6. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,480
    2,683
    Not many complain about the CR being too bright once they get it dialled in. Depending on how old the amp is getting the speaker broken in makes a difference. I put different power tubes in (because I had them sitting around) which also improved things.
    Like I say the eq is sensitive. Half a gnats makes a big difference.
    That said if I could change the red channel and take some of the mud away (as indicated above) I'd prob consider it. For me the red isn't really usable.
    SkyMonkey likes this.
  7. tmingle
    Jan 24, 2008
    461
    484
    Mifflintown, Pa.
    Thanks guys. That explains a lot. Has anybody scored an official schematic for these yet? The clean sounds great on this amp, but I feel all the OD channels are lacking something.
    I do recall removing C19 from my 40C a while back & did not care for it at all. I did not try different values on the 40C though.
  8. gregr
    Jul 30, 2014
    766
    851
    https://www.marshallforum.com/threa...-dsl-schematics-are-finally-out-there.105345/
    Besides removing the bright cap, R101 and C75 are a bit of a departure from the original JCM2k DSL. Restoring these to the original voicing will make a marked difference, if you should ever want to go in this direction. The input impedance was basically cut in half as well.
    I annotated some of the important changes in another discussion. Maybe I can dig it up.
  9. gregr
    Jul 30, 2014
    766
    851
  10. tmingle
    Jan 24, 2008
    461
    484
    Mifflintown, Pa.
  11. SkyMonkey
    3,828
    5,452
    Those (incomplete) schematics are all we have so far.
    They are from 2015 too. 3 years before the DSL40CR was released.
    So, prototypes at best.
  12. gregr
    Jul 30, 2014
    766
    851
    So is C74 populated on the amp in question?
    I’ve worked off the schematic for the DSL20H. There are indeed a few value changes and one area of cut & jumper rework, but the board layout still matches,
