Henry Sabbath
Hi everyone.. Thanks for having me in this community....
I´ve come across an issue with the Dsl40C that will like to know if anyone has experienced same issue as me...
I have a DSl40C from 2015 from a trade a little longer than 1 year an a half ago. Long story short, it needed a new power transformer as it was made for the american market with a 110-120 v tranny. As I´m from Spain, got a new original Marshall replacement PT from Tube amp Doctor in Germany that I pressume belongs to the latest DSL40C HR version as direct replacement. Nothing to worry about, just getting u into context.
Replace all tubes/valves as they where quite wasted and had inner rattling issues within power tubes and a blown preamp tube from the cathode follower... So I got some TAD el34bstr on the power section, V1 7025 TAD, V2 and V3 run of the mill chinesse shuaguang 12ax7 and on V4 an EHX 12ax7 lps... adjusted Bias settings on 36 Ma per tube...
Did perform C19 mod, which for me it´s a "Must do" situation, as I play Low tuned Sabbath- Hard Rock and Thrash styles... suits better to my ears and it´s a long debated mod...
Did convert the combo into a head and cabinet configuration and I´m quite happy with the amp for rehersals and small club gigs...
I´m quite picky about tone coloration and can tell the difference between minimal setting diferrences in amps, pedals and whatnot... So I have come across an issue between channels...
To begin with any switch on the front panel interacts between the channel not being used.. let me explain... if you are on the ultra channel and engage the clean/crunch switch from the classic gain channel, you will get a quite subtle increase in gain on your ultra channel, like having 1 more half gain stage of some sort...
also if you have your footswitch connected and engage the front panel channel switch you will notice another subtle increase of gain structure... so as it is one channel amp with different modes..it does bleed gain and cloration in more or less amount to your ultra channel...
And Again, if you have a patch cable in your loop effects engage or not, you will notice gain increase and tone coloration in a good way...
Now, this is more or less normal in many models and manufacturers as I have come across this issue through the years (I worked as a Music Merchant for 15 years and been at Namm and factory tours from various big brands)..
But the Issue here is that whenever you switch channels between classic and Ultra channel is that the tone gets some how shaped and losses low end on the ultra channel, but if you engage back to clean channel and straight back to ultra channel, the tone gets restored and gets back that low end and slight gain increase... So it happens on the follwing pattern:
1- fire up your amp on classic channel..
2- switch to ultra channel.. and will sound thick, tight and rich harmonics (good tone)
3- switch to classic channel back again
4- switch again back to ultra channel and you will notice that the tone has decrease in gain, low end ,thicknes..and a bit nasal sounding with shaped mids.. (bad tone)
5- switch back to classic quickly.. and..
6- switch into ultra channel and you get back to number 2 (good tone), restored gain, tone and harmonics... and so forth if you keep doing the operation as described..
So there is some bleeding tone issues between channels so it does not return to the same tone characteristics when you switch between channels, like some relay or transistor getting funny and not letting pass through the signal with the same properties.. or some sort of signal trace loss somewhere in the circuit..
Has anyone come across this issue or check it if does behave like mine????
thanks for your time and Crank up your DSL!!!
