dbf909
- Joined
- Mar 9, 2010
- Messages
- 168
- Reaction score
- 69
I recently picked up a used DSL20CR and have been considering rolling some tubes through it. I've got quite a few old and new preamp and power tubes to play with. I've been doing a bit of investigation into what other folks have found works for them and not surprisingly there is a lot of info out there.
At the moment, the amp is sporting all original Marshall branded tubes. I've been putting it through it's paces for the last couple of days and I'm generally pleased with the way it sounds. I rolled some Speakers through it and settled on a UK G12M Greenback for now.
I've had a number of other DSLs including a JCM2K DSL50 and a DSL40C. On those amps I pretty much lived on the Green channel. I rarely used the Red channel due to the type of music I mostly play. However, the 20 doesn't have quite the range of Clean to Crunch that the other DSLs do and there seems to be a pretty dramatic step in gain from Green to Red. So I'd like to tame the Red channel a bit and see if I can reduce the gain/distortion step from one to the other.
I did pick up on a thread in my searches that discussed the use of the ECC832/ECC823 type of tube with different triodes to accomplish this to some degree. I have used 12dw7 (ECC832) in some tweed circuits to great result and I remembered that I have one or two in the tube bin (not JJs but GE or Sylvania).
In looking at the schematic for the DSL20CR (marked DSL15 but I think it is the same preamp), it looks like the Green channel only uses V1.1 (pins 1, 2, 3) and V2.2 (pins 6, 7, 8) for a total of 2 stages. Switching to the Red channel essentially adds the other two triodes - V1.2 (pins 6, 7, 8) and V2.1 (pins 1, 2, 3) - in between for a total of 4 gain stages. I could probably be satisfied with only adding a single stage for the Red channel but there is no easy way to do that without modifying the PCB to eliminate one of the stages.
Having jogged my memory of the 12DW7/ECC832 I thought maybe this would be a good approach for this amp to kind of get toward that direction - reducing the gain of one of the stages might be what I'm looking for.
So the conventional approach to doing this would be to replace V1 with one of these tubes. Half of V1 is used for both Green and Red and the other half is added just for Red, If the Red half was the lower gain triode, this would work. Unfortunately, on the 12DW7/ECC832 the high gain (100) triode is pins 6, 7, 8 and the low gain (20) triode is pins 1, 2, 3 so this would not have the result I'm looking for - the first gain stage (which is shared by both Green and Red) would get the lower gain triode and thus it would just lower the overall gain in both channels.
The obvious answer then is to use the JJ ECC823 which swaps the high and low gain triodes from the 12DW7/ECC832. With this tube in V1, the high gain (100) triode is pins 1, 2, 3 which is the shared stage. The low gain (20) triode is pins 6, 7, 8 which corresponds to the first of the 2 stages that are switched in with the Red channel. The result is that the Red channel with all 4 stages in place is not quite as gainy but the Green channel remains the same.
However, I don't have an ECC823 in my collection and they seem to be pretty rare these days so not a short term option.
But in looking at the schematic again, it appears that if I substitute a 12DW7/ECC832 for V2, it would essentially accomplish the goal. Specifically, the high gain (100) triode (pins 6, 7, 8) would be V2.2 which is shared by both Green and Red and the low gain (20) triode (pins 1, 2, 3) would be V2.1 which is the second of the 2 stages that are switched in with the Red channel. On paper and at a high level, it seems like this should work.
Now I know that in a cascaded gain design, the placement/order of the interstage gains can make as large or larger difference in the tone and drive of the circuit as the amounts of gain in each stage. So there may be some interesting effects of shuffling these around but I think that this is worth trying out.
Also, by extension, it might even make sense to sub both V1 with an ECC823 AND V2 with a 12DW7/ECC832. Then both of the stages switched into the Red channel would be lower gain but together might be just the right amount...
So if you've made it this far into the post, congratulations and thank you for bearing with me. I have a few questions - has anyone done this experiment on a DSL20CR? Is there a significant difference between the two approaches (V1 vs V2)? Has anyone tried both?
If I can find an ECC823, I will definitely try all of these combinations and report my results. In the mean time, I will try the 12DW7 in V2 in the next few days if I can find the ones I have.
