Markfresh
- Joined
- Feb 23, 2018
- Messages
- 151
- Reaction score
- 137
I used the speaker output from the JCM1 (No loop), but the signal is too hot to re- amplify. Check before you do this but I'm sure the balanced output from the DSL1 is still the speaker output in low power mode. You will be missing the ECC82 in the chain by using the loop. This may be the correct way to go though....as I said check before using. It did no harm to either of my amps when using the speaker output.
Thanks for the reply.
I was only going to go out from the Dsl send in the loop not from speaker out.
Which as originofthespecies said will bypass the Dsl power section ( so yes bypassing the ECC82), but using the origins power amp tubes instead, by plugging into the origins return input on the loop.
