DSL100HR Amp Schem and Bias
Discussion in 'Marshall Amps' started by David Reid, Jan 17, 2021.
Tags:
  1. David Reid
    David Reid New Member
    Jan 17, 2021
    2
    I got myself a new amp head and was wondering where to find the schematics and bias setting for the tubes in this head? Can anyone help me with this.
    Mitchell Pearrow and SkyMonkey like this.
  2. South Park
    3,417
    2,940
    Is thar a problem with the amp . If it sounds good leave it as is
  3. SkyMonkey
    3,092
    4,059
    Hi @David Reid and welcome to the MF :welcome:
    Someone did post some DSL100HR schematics but the full set is still incomplete.
    They are dated 2015, so are most likely early drafts from before production started.
    The actual amps are likely to differ in some ways from these early drafts.
    https://www.marshallforum.com/threa...cs-are-finally-out-there.105345/#post-1779118
    There have been several bias threads for the DSL100HR.
    Here's one: https://www.marshallforum.com/threads/dsl100hr-external-bias-point-question.100955/
    Mitchell Pearrow and David Reid like this.
  4. Max Gahne
    Max Gahne Active Member
    Dec 1, 2020
    112
    130
    I don't have a DSL100 but looking at the schematics I would be thoughtful about biasing it. It appears to change bias voltage to match the hi/lo power voltage using optocoupler LTV826. I would want to measure factory bias voltage and current in both hi and lo power modes and think about what they've done. Then make sure I kept both hi and low bias current in a safe range if I tinkered with it. It appears that when you bias it on hi power you're also changing the lo power bias and vice versa. It might be possible to get one or the other out of range. Or maybe not. The factory setting would be in range for both power modes. I agree with South Park, if it sounds good leave it alone.
  5. David Reid
    Jan 17, 2021
    2
    Thank you very much!
    SkyMonkey likes this.
  6. Mitchell Pearrow
    13,007
    24,257
    :welcome: To the forum
    SkyMonkey and K2JLX like this.
