Down Brownie™ 6g3 Brown Deluxe From Cutthroat Audio; Check Out The Keith Nelson Demo!
Discussion in 'Member Classifieds' started by Ron W, Dec 8, 2016.
  1. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Down Brownie™ is a faithful recreation of the revered Brown Deluxe 6G3 from Cutthroat Audio. Not a kit, and not your father's 6G3, as the saying goes (well, sort of).
    This old-school build "mini-Marshall" has a British and Brown channel, Mercury Magnetics iron, Weber Alnico 12A125-S, Rich II Mod PPIMV, push/pull pot for channel "jumpering" and bright cap "lift", switchable tube/ss rectifier, switchable 6G3/5E3/JTM45 negative feedback, 4/8/16 ohm selectors and adjustable bias trim pot.
    A full and complete description of the Down Brownie™ is here. $1995 + shipping, fully equipped.
    Here are some pics:
    liontato likes this.
  2. Jakeboy
    Jakeboy Well-Known Member
    Dec 15, 2010
    612
    385
    Missouri
    Wow...the 6g3 is a mini-Marshall indeed....I have a Lil Dawg ChocoDawg that rocks. You should sell a boatload of these as you have made it better by eliminating the nearly useless "Normal" channel and replaced it with a British channel...did you modify the Normal channel or just replace it altogether with the Brit?
  3. Jakeboy
    Dec 15, 2010
    612
    385
    Missouri
    Absolutely killer build, btw...GLWTS
  4. NarbneK
    NarbneK Member
    Dec 31, 2012
    77
    26
    Southern Indiana
    A friend has a wonderful sounding original brown Deluxe. This looks even better; and that would be tough to do! Great looking amp.
  5. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Thanks for the feedback, Jake!
    The 6G3 normal channel went bye-bye. Basically, V1 goes from a shared to split cathode. V1A (British channel) has its own specific bypass cap, cathode resistor and coupling cap, for a 1987 lead type voicing. The tone pot on the British channel uses a .022 cap (same as Brown channel), instead of the stock .01 tone cap.
    V1B (Brown channel) is the stone stock 6G3 "Bright" channel circuit. Both channels keep the stock 500pF bright cap, which you can "lift" on the Brit channel.
  6. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Thanks! Will be working on cutting some audio clips tomorrow...
    NarbneK likes this.
  7. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Here are some short Les Paul clips on the bridge pickup. All recorded dry. Signal chain = R9 + Royal Wulff 12' lo-cap cable + Down Brownie. Volume/Tone and Rectifier setting are in the filenames. British channel first, Brown channel next, and then British/Brown channels jumpered:
    LP neck pickup and Strat clips to follow...
  8. coldengray
    coldengray Active Member VIP Member
    May 19, 2011
    409
    192
    This is a killer idea from a great guy and the price is right!
  9. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Here are a few more short Les Paul clips on the neck pickup. All recorded dry. Signal chain = R9 + Royal Wulff 12' lo-cap cable + Down Brownie. Volume/Tone and Rectifier setting are in the filenames. British channel first, Brown channel next, and then British/Brown channels jumpered:
    Strat clips next...
  10. SmokeyDopey
    Mar 9, 2011
    11,636
    7,445
    Argentina
    Wow, that looks awesome! Very cool options/features.
  11. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Thanks Smokey!
  12. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Per some requests, here are some Strat neck pickup clips. All recorded dry. Signal chain = John Cruz Masterbuilt '55 Strat +12' Royal Wulff Lo Cap cable + Down Brownie. Volume/Tone and Rectifier setting are in the filenames. British channel first, Brown channel next, and then British/Brown channels jumpered:
    I will work on putting up some Tele clips over the weekend...maybe some 5 string open G Keef riffs...
  13. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Happy New Year and thanks for all of the positive feedback. More clips coming when MM iron for current build gets here. The next DB will be available mid-January.
  14. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Thanks to everybody who's commented or got in touch. Received (3) deposits this week (!) for the January, February and March slots. As a result, I've decided to add an additional February and March slot. Shoot me a PM or call me at the shop if you'd like to discuss placing one on hold.
    Anybody heading to NAMM next week?
  15. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    4,105
    3,565
    Dallas
    Beautiful amp, fantastic features, sounds amazing, and all for an awesome price! Wow, very, very impressive!!!
  16. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Thanks again to all for the positive feedback. Shipping DB1008 on Monday. Next available slot is DB1014 for late April/early May delivery.
  17. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    New Imgur links added to the original OP.
  18. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    I recently had the pleasure of meeting up with Keith Nelson at his SoCal studio for the delivery of his Down Brownie. What I thought was going to be a brief visit turned into an extended hang where we visited about life, music and of course gear. Keith has some awesome chops, and is a real gentleman and all round cool dude. Thanks, Keith!
    Stay tuned for a killer Down Brownie demo from Keith...
  19. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Check out this Down Brownie demo track laid down by Keith Nelson that just plain rocks:
    Here are Keith's liner notes he sent with guitar & amp settings, signal path, etc.:
    Left speaker:
    '73 Tele Cst, Bridge position, all V and T up
    Amp:
    Brown channel, tube recto, 6g3, vol 7, tone 8.5, MV all the way up
    Mic pre: vintage Neve 1073, no eq, no compression, sm57 (60%) and Beyer Dynamic M160 (40%) close mics right on speaker cloth
    Right speaker:
    1959 Les Paul Jr, double cut, V and T all the way up
    Amp:
    British channel, SS recto, JTM 45, vol 7, tone 8.5, MV all the way up
    Same signal path as Tele
    Center gtr:
    Dave Johnson R9, Sheptone Tribute pickups, bridge position. Vol and tone on 10
    Amp:
    British Channel "Jumped", Tube recto, 5e3, Brit- v 8.5, t 7.5, Brown- v8, t 3 MV all the way up
    Same signal path and blend as Tele and LP Jr
    One more thing... center guitar (les paul) has just a hint of spring Reverb on at mix down. All other guitars are bone dry. And I played drums and bass as well.
    Thank you, Keith. You rock, sir!
  20. Ron W
    Ron W Active Member
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    I had the privilege and pleasure of having Joe Bonamassa put a Down Brownie through its paces this week before the show here in Spokane, WA. It's well-known that Joe is a big fan of the 6G3's, so his feedback and very kind words were greatly appreciated. Hearing him play Snakebite through a very cranked DB 1025 was quite a thrill:
    Here's a shot of him with my buddy's uber-rare '63 Korina Strat:
    Joe was incredibly generous with his time and knowledge that day, and shared his vintage arsenal for this tour, including his most recent '58 Flying V. He also gave us the rundown on his current backline, which consists of (4) HP Tweed Twins; (2) vintage ones and the first (2) of the just announced JB signature 5F8 Tweed Twin reissues.
    We thoroughly enjoyed the show, and were both in agreement that the '58 V sounded absolutely unreal through those HPTT's. Thanks, Joe!
    liontato and coldengray like this.
