Dont beat me up cause its not a Marshall How to connect line 6 spider 4 HD150 to 1960 cab
Discussion in 'Cabinets & Speakers' started by Doug63, Jul 14, 2021.
  1. Doug63
    Doug63 New Member
    Nov 4, 2014
    27
    21
    The line 6 head has 2 8ohm inputs in stereo, My 1960 Marshall cab has stereo 8 ohms and 4/16 ohm connections do I have to only run the head in stereo and have 2 cables running from head to cab?
  2. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,656
    2,818
    Massachusetts, USA
    I've never used that amp but I skimmed over the guides.
    -Looks like if you run two speaker cables from the Line6 it will give a 4 ohm load total per the screenshot below. But to run a stock 1960 at 4 ohms it has to be set to mono and it would use 1 speaker cable in. No dice.
    -To run an 8 ohm load from the Line6, you'd use one jack on the amp but to run the 1960 at 8 ohms you'd have to use one side of the stereo connection (2 speakers). Again not familiar with that amp but I'm assuming you'd then lose stereo capability.
    I don't think either setup is ideal. Maybe someone else has another opinion but it seems like the "safest" configuration is to use a single 8 ohm out from the Line6 into a single stereo 8 ohm in on the 1960 (with the stereo switch set accordingly), yielding use of 2 speakers on the 1960.
  3. Doug63
    Doug63 New Member
    Nov 4, 2014
    27
    21
    thats why I am confused on the back of my cab is pictured it says 8 ohm left and 8 ohm right so I would have to use 2 cables and switch cab to stereo?
  4. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    1,082
    1,240
    The Spider IV HD150 is true stereo -- two separate power amps, each wanting a minimum 8 ohm load.
    So yes, set the switch on the 1960 to stereo and use two speaker cables.
    Edited to add: the quick start and advanced manuals are contradictory and confusing. So Line 6 added this FAQ about how to hook up the Spider IV head to a cab.
    https://line6.com/support/page/kb/a...-iv-head-and-cabinet-and-connection-faq-r477/
  5. JBA
    JBA Well-Known Member
    Nov 14, 2016
    545
    620
    Oh dude don't use a Marshall cab.. that will just make your amp sound all fizzy.
    Crikey likes this.
  6. Matthews Guitars
    4,467
    6,712
    Set the cabinet switch to stereo. Run two speaker cables, two from the amp and to the cabinet. Done.
    And start setting aside some money every month so you can join the Marshall owner's club sooner or later.
  7. Doug63
    Doug63 New Member
    Nov 4, 2014
    27
    21
    already have 2 marshall tube heads but there are things I like on the L6 heads for certain songs I play. Was just not sure how the stereo part worked
  8. Doug63
    Doug63 New Member
    Nov 4, 2014
    27
    21
    Actually I am quite impressed with the sound
  9. JBA
    Nov 14, 2016
    545
    620
    though that was a pretty obvious joke :D
