Does Anyone Use Preamp Tubes Other than 12AX7 Type?
Discussion in 'Let's Talk Vintage' started by matttornado, Sep 4, 2020.
  1. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    1,340
    796
    I have an old 70's Super lead that is a gain monster, even on modest volume settings.
    Lately, I' been working on getting my Russian Big Muff to work with this amp and it has been very challenging to say the least but I'm finally there with single coil pickups, amp volumes set less than half way & and an Overdrive pushing the big muff to EQ the sound so it's not muffledbut cuts through.
    I just put, I think, a 12AY7? in V1 to tame this amp a little so the Big Muff has room to breathe so to speak. It seemed to help a little.
    So If I put say a 12AU7 in all three pre-amp slots, what would the amp sound like, a clean Fender sort of?
    Bottom line is that I'm trying to clean this amp up so it's more distortion pedal friendly.
    I played this amp cranked on 10 with various attenuators & no drive pedals for half my life & I want to go a different route. I like having to step on a pedal for distortion / FUZZ istead of the cranked Marshall sound. Tired of it.
    Anyone else try lower gain pr-amp tubes in there Super Leads?
  2. pedecamp
    16,013
    14,244
    Unless the amp has been modded, I'm surprised to hear you cant put the volume on 2 or 3 which would be blazing loud but clean, then stomp a pedal for gain. Maybe a life time ago you had a gain mod added to the amp and you dont remember? Maybe have a tech check to see if the amp is stock or not and put it back to stock if thats the case. :yesway:
    neikeel likes this.
  3. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    962
    1,180
    Ohio
    You might want to try a Mullard CV4004 for V101. It's a special version of the 12AX7. I use four of them in my amp. They test about 20% higher (micromhos) than Mullard 12AX7s. Lots of headroom, and the clean channel in my Marshall never sounded so good.
    matttornado likes this.
  4. rjohns1
    rjohns1 Well-Known Member
    Dec 30, 2009
    1,602
    420
    I really like the JJ ecc83MG tubes in v2 and v3 of my 40CR.
    MarshallDog likes this.
  5. South Park
    3,337
    2,844
    Using the 12au7 in all tube sockets you might not get the right tone. But try it to see . You don’t get a name like that for nothing.
  6. Amadeus91
    Amadeus91 Well-Known Member
    Apr 9, 2019
    178
    252
    Madfinger likes this.
  7. AlvisX
    AlvisX Well-Known Member Gold Supporting Member
    May 31, 2011
    5,090
    10,469
    I-55 Corridor
    In my guitar specific amps ,especially the cascade preamp ones, I'll likely use a 5751
    I like 12Ay7 in my harmonica amp and 12au7 or 12ay7 for bass ...to clean up the farties
    !2at7 is a great phase inverter
  8. Filipe Soares
    Mar 8, 2019
    1,772
    3,195
    I'm using a 5751 as V1 in my 5150III
  9. matttornado
    Mar 14, 2012
    1,340
    796
    thanks for the replies. i guess i’ll have to experiment a little more.
    BTW: my amp is a stock superlead circuit except i added a ppimv.
  10. matttornado
    Mar 14, 2012
    1,340
    796
    it’s mostly stock. i made a few minor component value changes , added a cap, and changed it to use el34s.
    i been this amps tech for 20 years and must have tried every mod under the sun. now it’s mostly stock. go figure.
    amp sounds cranked on 2. always have always will.
    been down that rabbit hole trying to find out why.....,
    pedecamp likes this.
  11. MarshallDog
    Nov 28, 2010
    15,056
    16,753
    Taintville
    I have experimented BUT always end up back to stock 12ax7 types. Just sounds better over all to me.
  12. South Park
    3,337
    2,844
    The 12ax7 works because the preamp is designed that way . Audio circuits are designed to be leaner . The power curve is a straight line in all tubes . When you mismatch the tubes it is not the same . You have tone caps rolling off frequencies at different power levels . So if you want to make this work you need a slide ruler
    Peter McAteer likes this.
  13. Trapland
    Trapland Running Into Walls Silver Supporting Member
    Dec 5, 2013
    1,361
    1,252
    Minneapolis
    Consider moving the negative feedback wire to a different tap. Or changing the NFB resistor to a lower value. This should give you much more volume before distortion and will take Your pedal better.
  14. matttornado
    Mar 14, 2012
    1,340
    796
    I have a 27k NFB R on the speaker tap along with my ppimv.
    that does help a lot.
    neikeel likes this.
  15. matttornado
    Mar 14, 2012
    1,340
    796
    thanks for all the replies!
  16. neikeel
    5,164
    3,640
    Using CV4004 (M8137) or 5751 across the preamp will probably work well. NFB 27k/16 helps (presume 16 ohm cabs?).
    There are ways to clean your preamp up but it depends what your ‘stock’ spec is at the moment. (Hint : pics please!)
  17. Jim Jones
    Jim Jones New Member
    Aug 30, 2020
    9
    8
    Does yours have a 5000pF bright cap on the Bright channel volume? If so that basically turns the volume into an On-Off switch. 100pF-500pF works better there for me.
  18. matttornado
    Mar 14, 2012
    1,340
    796
    That was first thing I tried many years ago!;) thanks for the suggestion though.
    I took that cap off and left it off 20 years ago.
    Jim Jones likes this.
  19. matttornado
    Mar 14, 2012
    1,340
    796
    I don't have a pic at the moment but here are the specs all done by me:
    1974 Metal Panel 1959 Super Lead:
    - no bright cap on volume 1 (5000pF cap removed)
    - 0.022 uF orange drop on V1B (changed from a 0.0022uF original spec.)
    - added 0.68uF orange drop cap on V2A (like plexi's had)
    - LAR -MAR PPIMV added
    - NF 27K / speaker jack (originally was a 100K to 4 ohm tap)
    - converted to EL34s
    - presence control changed to 0.1 uF plexi spec.
  20. Jim Jones
    Aug 30, 2020
    9
    8
    Removing the .68 cathode bypass cap will help the cause.
