Do you modify the wiring in your guitars?
Discussion in 'Guitars' started by Alligatorbling, Aug 30, 2020.
  1. Alligatorbling
    Alligatorbling Well-Known Member
    May 27, 2020
    803
    1,017
    I rewired my HSS stat so that is has one master volume and one master tone. The 2nd tone knob is a dummy with nothing wired to it. I used a random pot I found in my parts drawer. The two functioning pots are CTS 500k audio taper. I have a .033 orange drop capacitor.
    What about you? Do you like to modify the circuitry in your guitars?
  2. anitoli
    9,229
    12,260
  3. LPMarshall hack
    Nov 18, 2009
    11,110
    11,274
    San Diego, CA
    I do not
    Sapient likes this.
  4. kebek
    kebek Active Member
    Mar 18, 2009
    942
    249
    Same here, except pickup upgrades sometimes
  5. Matthews Guitars
    3,094
    4,624
    Since every guitar I currently own is one I built, I'd say that the answer has to be yes. No two are wired in exactly the same way.
  6. LPMarshall hack
    Nov 18, 2009
    11,110
    11,274
    San Diego, CA
    I wish I was skilled enough to do wiring work.
  7. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    989
    897
    Brit in California
    I do fairly often. Though I started just buying drop in wiring harnesses for my more expensive guitars. I don't really have room to work with a soldering iron safely and get annoyed with not having three hands. My newest strat has a Neck/Bridge blender pot, universal tone and volume pots From SmokeyB's ebay store and I really like it.
    If I have hot humbuckers, especially something like a JB in the bridge I always add a coil split to the inside coil furthest from the bridge to get a nice kind of stratty sound. My last HSS strat had a small push/push switch that added the neck to whatever 5 way switch setting you were using.
    I guess I just like having the options, sometimes I do use them. Mostly when I'm using a humbucker guitar, feeling lazy and don't fancy digging out a strat.
    Sustainium likes this.
  8. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    1,247
    1,503
    Ohio
    No, for two reasons:
    1. There are no wires in a Parker Fly.
    2. Rather than modify equipment, I buy what I want to begin with.
  9. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    926
    913
    I started playing in the early '70s just as the modding craze was taking off. And my dad was an electrical engineer who taught me what all the components are, what they do, and how to solder long before I picked up a guitar. So yeah, I enjoyed experimenting and tried just about everything over the years.
    My second guitar was a Les Paul Deluxe. I removed the pickup covers and converted the pickups to 4 conductors, then made a new control cover plate with a bunch of slide switches for splitting, phase, series/parallel -- and discovered I didn't particularly like any of the different sounds. Had other guitars after that with various switches already installed and felt the same, so I don't bother with any of that stuff.
    Tried all the cap types. I actually prefer ceramic disks -- they seem to add a little growl. Not enough to bother changing if a guitar has something else, though. (I do change cap values if I don't like the stock voicing -- my Strat came with a vintage style 0.1 that was way too dark and had to go.)
    I like the way the tone darkens when I roll down the volume, so I've never bothered with treble bleeds or '50s wiring.
    I've tried neck + bridge on Strats and don't dig it.
    Pretty much, the only mod that's 100% a winner for me is Strats need a bridge tone control, with a no-load tone pot so I can still get that brash wide open tone on the occasions I want it.
    Recently got a 2013 SG with the "dreaded" pcb and the tiniest, littlest, cutest ceramic caps I've ever seen. I don't feel any urge to change a thing.
    Pickup changes are a different subject, I think.
  10. John BNY
    John BNY Well-Known Member Silver Supporting Member
    Jul 13, 2013
    2,080
    3,284
    New York
    I generally don't mod, unless I'm swapping pickups. I did, however, rewire my HSS strat so that the rear tone knob controls both the middle and bridge pickups. Otherwise, the bridge humbucker was way too ice-picky. It is a very easy mod.
  11. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,314
    2,317
    Wilton NSW
    I don't have any guitars without my own wiring mods! its part of the fun for me.
    My two best are a 1991 Gibson LP studio, and a 2010 Fender HSS Strat. When I got these, I'd previously rewired a few beater guitars, so I put in exactly what I liked best, and haven't changed them in quite a few years now.
  12. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    1,121
    2,296
    :coffee: What exactly did you do to the LP?
  13. JohnH
    May 31, 2008
    4,314
    2,317
    Wilton NSW
  14. Sustainium
    Oct 4, 2019
    1,121
    2,296
  15. roycaster
    roycaster Well-Known Member
    Dec 26, 2013
    329
    264
    I like to wire the neck position to bypass the tone control on Telecasters…
  16. Trumpet Rider
    Trumpet Rider Well-Known Member
    Nov 8, 2016
    2,243
    4,251
    I have re-wired one guitar, my Squier Strat. I replaced the bridge pickup with a Hot Rails. I replaced all of the pots and the 5-way switch with American Strat parts. I wired the rear tone knob to the bridge pickup. Pretty typical things to do to a Stat I guess.
  17. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    469
    549
    Currently my old mij stratocaster has HSS....master volume....1 tone for middle and neck 1 tone for bridge a coil tap switch for bridge HB and another toggle to turn the neck pup on independent of the switch....allowing bridge and neck in position 1 and all three in position 2.....has a Duncan JB in the bridge and two formvar dimarzio singles in mid/ neck that I peeled windings off to make them more vintagey sounding crl switch cts pots orange drop .022s
  18. SkyMonkey
    3,080
    4,028
    I do my own wiring and have experimented with a few mods.
    My HH guitar with 2xVol & 1xTone is wired with 3 Push/Pulls for coil splits (simultaneous) and Series/Parallel (individual).
    I have wired SSS Strats in the past with a 3-way for neck and bridge.
    One Vol for N+B & Tone for all 3, and the middle knob for Middle Vol.
    I have a HSS I tried a selection of pickups in and decided to install terminal connectors in the cavity to avoid loads of re-soldering.
    It's all good fun. :)
    KraftyBob likes this.
  19. pedecamp
    16,178
    14,549
    Its not a matter of like, its a matter of necessity to get the tone and functionality you need in a guitar. Most all of my guitars are rewired I cant say I "liked" doing it though. :yesway:
  20. Alligatorbling
    May 27, 2020
    803
    1,017
    Its easy bro, just print out a diagram and follow it to a T. Think of it as paint by numbers.
    Learning to solder doesn't take long.
