Disconnecting the reverb tank
Discussion in 'The Workbench' started by slade, Oct 16, 2021.
  1. slade
    slade Member
    Oct 8, 2021
    58
    79
    Maryland
    Hello, I have a jcm 2000 tsl and wanted to know if I can disconnect the rca wires on the tank and still be able to play the amp? I’m always hearing the reverb.
    StrummerJoe likes this.
  2. Pete Farrington
    Jan 18, 2021
    916
    928
    Staffordshire UK
  3. StrummerJoe
    StrummerJoe Well-Known Member
    May 3, 2021
    2,335
    5,950
    Go for it.
  4. slade
    slade Member
    Oct 8, 2021
    58
    79
    Maryland
    Cool, thanks guys.
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    3,001
    2,915
    Yeah, who needs reverb anyway? We play Marshalls here, not Fenders !!
    slade, Pete Farrington and SkyMonkey like this.
  6. slade
    slade Member
    Oct 8, 2021
    58
    79
    Maryland
    Disconnected the reverb tank and that made a big difference in the tone. Much, much better.
    Edgar Frog and StrummerJoe like this.
  7. StrummerJoe
    May 3, 2021
    2,335
    5,950
    I'm a 'verb addict myself, but glad it works for you! :cheers:
    slade and Edgar Frog like this.
  8. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    1,380
    1,372
    NJ
  9. alpha al
    alpha al Active Member
    Oct 19, 2017
    72
    103
    Gastonia, NC
    I would recommend insulating the male RCA pins with tape. You don't want them grounding out with a solid state drive circuit. It could blow the driver IC.
    StrummerJoe and Pete Farrington like this.
  10. Pete Farrington
    Jan 18, 2021
    916
    928
    Staffordshire UK
    It’s bad practice to drive a transformer coupled valve output stage into an open circuit. As there’s risk of damage. To mitigate that, I suggest to remove the valve or fit a load resistor.
  11. slade
    slade Member
    Oct 8, 2021
    58
    79
    Maryland
    I removed the rca cable after I tested the amp. I was always hearing the reverb and changing the setting never changed the reverb.
  12. thetragichero
    Jun 6, 2010
    3,348
    1,303
    flo rida
    as mentioned, transformer-coupled reverb (like you'll find in older-style fenders and probably marshalls, although frankly i don't look at reverb in marshall schematics) should have a load for the driver. some old ampegs use capacitor-coupled reverb (this is what i usually do on my own builds, because i can use a 12dw7 for both driver and recovery. no additional triodes needed, no transformer. nice and simple)
    Pete Farrington likes this.
