Did I just mod the wrong Board!!!
Discussion in 'The Workbench' started by Shae201, Aug 13, 2020.
  1. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    661
    699
    For the OD2 To OD1 mod, did I change components on the wrong Board? This is the pic of the main board. Is it the board the knobs are attached to? IMG_20200813_215532065~2_copy_2000x1500.jpg
  2. South Park
    2,890
    2,388
    Drop the soldering iron and walk away
  3. Shae201
    Dec 20, 2015
    661
    699
    Wow, that helped.
  4. StingRay85
    StingRay85 Well-Known Member
    Aug 18, 2019
    518
    255
    If you're clueless, then you shouldn't be holding an iron
  5. Neil Skene
    Neil Skene Well-Known Member
    Oct 3, 2011
    952
    1,592
    Australia
    Not sure, I think you're in the right amp though.
    I wouldn't drop the iron, If I dropped my guitar the first time I made a mistake I would have only played for 30 seconds instead of 30 years.
  6. StingRay85
    Aug 18, 2019
    518
    255
    This PCB style board is probably not something a beginner should go for, but anyways OP should be able to read a schematic and identify his amp before proceeding
    thetragichero likes this.
  7. Shae201
    Dec 20, 2015
    661
    699
    well I'm not completely clueless I've been a commercial and industrial electrician for 20 years I just have not had to go through basic circuitry since apprenticeship class I had a simple question there's two boards on that amp your response sounds like someone who's actually never picked up a soldering iron before. That's why in the jvm forms they tell you what number of component to change I did not realize the front control mounted board had the exact same number designations.
    KraftyBob and Sustainium like this.
  8. Shae201
    Dec 20, 2015
    661
    699
    Can you read a schematic that's my question . It would be very easy for me to be like you in just fork over some money for a tech to do the repair for me but unlike you I'm actually going to take the time to try and learn something new and not just flex my muscles in a forum.
    KraftyBob likes this.
  9. South Park
    2,890
    2,388
    Printed circuit boards are not easy to trace things out that is the problem . The traces will lift and fall apart if worked to much . The best thing to do is put back to original . You can build a 2204 ptp board and all the mods you want
    thetragichero and Adieu like this.
  10. StingRay85
    Aug 18, 2019
    518
    255
    I can read a schematic and build my own amp from it, not to worry. But only p2p I don't mess around with PCBs.
    Maybe the issue is that you didn't provide us with all the info you got. You basically show a picture with a few circles, how can you expect people being helpful from that.
  11. Shae201
    Dec 20, 2015
    661
    699
    Not all questions can be answered by just anyone. People with the answer will respond to that question. I don't try to answer questions if my knowledge isn't pertanent to the subject.
  12. StingRay85
    Aug 18, 2019
    518
    255
    Ok mate, have fun with your project. I bet people will be eager to help you out after reading this topic and the way you respond to people. All the best
  13. Shae201
    Dec 20, 2015
    661
    699
    I've been here several years and never had problems. I know most of the regulars. Didn't mean to be so brazen but Im not keen on opening with sarcasm either. Thanks anyways though. Have a good weekend.
    ricksdisconnected and StingRay85 like this.
  14. South Park
    2,890
    2,388
    All amp builders will start out and get in over thar head this stuff is not easy . I did the same thing Can you explain the mods
    ricksdisconnected likes this.
  15. ricksdisconnected
    Aug 11, 2019
    3,887
    5,779
    causing trouble again i see @Shae201 :p:fever:
  16. Shae201
    Dec 20, 2015
    661
    699
    Ahhhh,just some JVM woes. Another rabbit hole I've fallen into.
  17. Shae201
    Dec 20, 2015
    661
    699
    JM5010 likes this.
  18. Shae201
    Dec 20, 2015
    661
    699
    It's my fault really, if I had of looked at the schematic and followed the OD circuit path instead of open the amp and immediately see the designation numbers on the first board I see I wouldn't have made the mistake. My joints are really clean so no major deal to pop the original components back in and do it properly.
    ricksdisconnected and South Park like this.
  19. thetragichero
    Jun 6, 2010
    2,625
    732
    flo rida
    i found i wasn't teachable until i had the humility to admit i may be in over my head and accept suggestions without getting defensive
    first amp i ever tried to mod was a dsl with the Joey mods and ended up destroying an already non-functioning amp, so i get it
    before i even plug the iron in I've thoroughly gone through the schematic, compared the device in front of me to the schematic (they're not always the same!), and possibly even marked the solder joints in going to desolder with a sharpie. that whole measure twice, cut once thing my father always tried to teach me that seemed like needless time wasting as a yout
    Shae201, StingRay85 and CraigP like this.
  20. South Park
    2,890
    2,388
    Before I started building amps I spent three years in night school. And that is just the beginning of it . We all have projects that don’t work that is part of the game . But you will get better the more research you do the better of you are
    Shae201 and thetragichero like this.
