Diagnosing DSL40C hissing noise
Discussion in 'The Workbench' started by Alex P, Sep 19, 2020.
  1. Alex P
    Alex P New Member
    Sep 19, 2020
    5
    I have a DSL40C with a bad hissing noise. I've tested for microphonic tubes and even just replaced the V1 preamp tube with a new one, which according to other people who had the same issue, fixed the hiss. I also moved the tubes in different combinations but the noise remains. I'm not sure what the noise could be now, any help? Thanks a lot.
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,692
    1,384
    We need more info. Is your guitar plugged in or not? Effects? Does the hiss get louder when you turn the amp up? Etc.
  3. Alex P
    Alex P New Member
    Sep 19, 2020
    5
    The amp makes the noise without a guitar being plugged in and it does get louder as I increase the gain/volume. It's especially prevalent in the high gain channel but it's abnormally loud. I'm not running any effects currently, so I know the noise is from the amp. I found a video that demonstrates the issue but the solutions I read in the comments did not work for mine:
  4. Chris-in-LA
    Jul 19, 2018
    1,692
    1,384
    Your video title says the amp is new, if so, return it. I wouldn’t even have that fixed under warranty unless that was my only option.
    MarshallDog likes this.
  5. Alex P
    Alex P New Member
    Sep 19, 2020
    5
    It's not my video, my amp is used.
  6. Chris-in-LA
    Jul 19, 2018
    1,692
    1,384
    I was afraid of that. Have you looked inside to see if anything is burned?
  7. Alex P
    Alex P New Member
    Sep 19, 2020
    5
    No I haven't, I'm not really confident enough with electrical work to open up the circuit, though I can say I've never smelled something burning within the amp.
  8. Chris-in-LA
    Jul 19, 2018
    1,692
    1,384
    It sounds like you’ve done most of the things that you are comfortable doing. I don’t know why other forum members haven’t offered any advice by now, I’m not familiar with your amp. If you have an effects loop you might try using a patch cable to connect those two jacks. If that doesn’t work you’ll probably have to take it to a tech.
  9. Chris-in-LA
    Jul 19, 2018
    1,692
    1,384
    You’ve swapped out preamp tubes, have you tried new power tubes?
  10. Alex P
    Alex P New Member
    Sep 19, 2020
    5
    I haven't tried power tubes as I wanted that to be the last resort since I'd have to pay a tech and buy more expensive tubes. I think I may have to take it to a tech since I've tried everything. What would a patch cable in the effects loop do?
  11. Chris-in-LA
    Jul 19, 2018
    1,692
    1,384
    Some loops have oxidation on the jacks and the cable bypasses them. Not sure how to explain.
