Daisy chain with the output of the Tc Electronic Polytune
Discussion in 'The Tone Zone' started by Marco m, Apr 10, 2021.
  1. Marco m
    Marco m Member
    Mar 3, 2021
    34
    39
    Hi,
    I am powering my pedalboard with a Truetone 1 Spot CS12.
    I use 10 pedals of 9V. The Truetone got 9 outputs of 9V. So I have to use one of the outputs for 2 pedals (like 2 overdrives).
    I just discovered that one of my pedals (a Tc Electronic Polytune) got an output for charging directly another pedal.
    Do you think that would it be better to charge my 10th pedal of the pedalboard with this ouput or sharing 1 output of the Truetone (like I'm doing until now) ?
    Thanks
    BatmansMarshall likes this.
  2. FracStrat
    FracStrat Well-Known Member Gold Supporting Member
    Jan 22, 2020
    741
    2,165
    Water Side of WA State
    As long as your total mA Draw is lower than 3000mA you should be fine ……
  3. WellBurnTheSky
    Mar 23, 2019
    1,207
    2,738
    Yeah, I do that with my CS7 and a Polytune, works fine as long as you don't go over the mA rating of the output you're on. In a nutshell, with an analog pedal, you'll be fine.
  4. BatmansMarshall
    May 15, 2020
    292
    397
    Lives in the mid-range.
    I would get a Furman power conditioner rack to protect that kit if you haven't already. 10 pedals and an isolation brick are worth surge protecting and removing the last trace of hum. Plug your amp into it also.
