Dagnall C2668 color code
Discussion in 'The Workbench' started by JM5010, May 10, 2021.
  1. JM5010
    JM5010 Active Member
    Nov 11, 2017
    453
    84
    Finishing up a build in which i’m confused about the wires on the primary side of this C2668.
    Which wires go to the output tube sockets and which one is the center tap?
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,448
    2,257
    On my Plexi, the brown goes to the high voltage and the red and white go to pin 3. Put your ohmmeter on the brown lead and check resistance to the red, and then to the white. You should get a similar reading.
    JM5010 and neikeel like this.
  3. neikeel
    5,802
    4,433
    Brown is CT
    But put a rubber grommet around that chassis hole before you wire it up or you will have more expensive sizzling.
    Pete Farrington and JM5010 like this.
  4. JM5010
    Nov 11, 2017
    453
    84
    According to a 2203 schematic found in Marstran, I believe the white wire is the CT?
  5. neikeel
    5,802
    4,433
    Put a meter on it and the middle one will be clear.
