Crank that Marshallboy
Discussion in 'Marshall Amps' started by Ebonyandpearl, Apr 16, 2021.
  1. Ebonyandpearl
    Ebonyandpearl New Member
    Apr 16, 2021
    6
    16
    Hey guys, I recently got a studio vintage 20. I live in a small apartment and it really limits how loud this can be (paper thin walls, you can hear people on the phone sometimes)
    I am using a -20db torpedo attenuator, and also a JHS little black box in the FX loop.
    Using these 2 to control volume work, but with the normal on 6+ and high treble on 4+ it’s not all that satisfying. Sometimes I throw a big muff, boost, or overdrive in front that helps get me closer to the tone I want but I really like the sound best when it’s cranked all the way up.
    I have read people say that cranking an amp to 10 for low volume playing for prolonged periods with an Attenuator will mess it up. Is this true?
  2. ricksdisconnected
    Aug 11, 2019
    6,009
    9,228
    :welcome:
    Ebonyandpearl likes this.
  3. Matthews Guitars
    3,757
    5,660
    Attenuators and other devices that allow you to play in an apartment with walls made of paper at least make it POSSIBLE but you are missing out on the experience of an amp cranked up and moving air. That's why some people get together with other musician friends and rent a space, maybe at the local rental storage facility, to use as a band practice room. Not so much for practicing for gigs, but as a place to jam and have some fun. You might want to look into that option. But be sure the place has GOOD security and at least the ability to double lock the door to your unit.
    I'm very lucky in that I can crank up as loud as I want to at home and nobody will complain. This morning I did exactly that. With a 100 watt Superlead. Cranked all the way. Etymotic ear plugs in my ears. It was SO fun.
  4. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,373
    2,148
    You should’ve gotten the studio classic. You can get a cranked sound with those at tv volume without an attenuator. But, no amp is really satisfying to play at whisper volume.
  5. Ebonyandpearl
    Apr 16, 2021
    6
    16
    Aside from it being less fun is there any problems for the life of the amp leaving it cranked all the way up with the attenuator all the time?
    I’m going to look into getting a studio lockout near by. I’m in Hollywood so there’s lots of options!
  6. slagg
    slagg Well-Known Member
    Apr 7, 2012
    650
    316
    Cheezeland Wi
    No harm with a good attenuator, but your tubes are gonna wear out faster.
  7. Ebonyandpearl
    Apr 16, 2021
    6
    16
    Awesome! Thank you all for the quick replies. I was going to sell this amp because I couldn’t come up with a good tone at low volume but with the gain dimed and a little dirt in the front it sounds great. I can live with it until I can find a good lockout near by I can make use of. Then I can finally get that speaker pushing some air
  8. ricksdisconnected
    Aug 11, 2019
    6,009
    9,228
    sounds like a plan bro.
    you are gonna stick around and be a regular member here yes? :cool:
  9. Ebonyandpearl
    Apr 16, 2021
    6
    16
    Oh definitely! I’ve been creeping the forums for a while just reading but I’ll be coming to chat now and share. On Monday I have a new R8 coming and I think it will be a good time to take that and the plexi to a studio to get loud. I can update then
  10. ricksdisconnected
    Aug 11, 2019
    6,009
    9,228
    good deal bro.
  11. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,288
    2,383
    :welcome:
    :cheers:
  12. Matthews Guitars
    3,757
    5,660
    I HIGHLY recommend that you buy a set of Etymotic High Fidelity earplugs. They're about 20 bucks from Sweetwater. Then, you can enjoy the full tone of a cranked amp without going stone deaf. They really work at reducing volume in your ears while letting everything sound the same as if you were not wearing ear protection, just quieter.
  13. coughlinkelly
    coughlinkelly Member
    Sep 12, 2013
    24
    37
    Ottawa, Canada
    I know it's expensive but I'm having incredible fun with my SV20 and Boss Waza Tube Expander. I can crank my amp and get that juicy power tube distortion through my 2x12 and have it at any volume I want...it's just fantastic. I've tried other attenuators including Ox Box and the Waza has just blown my mind in how well it works with Marshall amps. LIke I said, expensive (same cost as amp if not more) but so worth it! I'm now using it with a 100watt handwired marshall plexi and I'm heaven!
  14. Ebonyandpearl
    Apr 16, 2021
    6
    16
    Ok I’m sold! Attenuation is a must for the time being and this isn’t the first time I’ve read this. I have to try this thing
  15. Ebonyandpearl
    Apr 16, 2021
    6
    16
    I have some awesome ear pro but I’ll try these. I’m a Marine so I’m already half deaf
  16. Matthews Guitars
    3,757
    5,660
    Better to keep what's left of your hearing! We can't grow new ears yet!
  17. marshallmellowed
    Jun 26, 2009
    4,464
    6,431
    You might also consider the Bad Cat Unleash. It has the advantage of a foot switchable lead boost, and is also a re-amping device like the Waza, only without all the extra bells and whistles. I have the V1, like this one, works great with the SV20...
    https://reverb.com/p/bad-cat-unleas...gwhFVAJPdqOBrHPNx7-BQSkKcUNmcSORoCPbYQAvD_BwE
    Here's a V2...
    https://reverb.com/p/bad-cat-unleas...H39DEP-WQ8cn7gWatBtk3q8QAAgyBibxoCOMYQAvD_BwE
  18. Mitchell Pearrow
    13,512
    25,580
    :welcome:
    TO THE FORUM OF LOUD
    We are almost neighbors
    Riverside area
    Cheers
    Mitch
