Classical Guitar - how's my tone?
Discussion in 'The Cellar' started by Australian, Mar 2, 2021.
  1. Australian
    Australian Green Beret Silver Supporting Member VIP Member
    Apr 20, 2009
    18,202
    10,191
    I'm doing some test recordings on this classical guitar piece of mine. Its just a rough example-parts of it, but can you tell me how the guitar sounds? Be as honest and brutal as you like.
    A mix?
    B mix?
    C mix (the complete piece)
    Some snippets of some other Pieces I just recorded tonight: Bach/ Albeniz Piazolla Romance
  2. Biddlin
    Biddlin Well-Known Member
    Aug 21, 2013
    4,120
    4,773
    Old Foothill Farms, Califusa
    dull.
    Australian likes this.
  3. pedecamp
    16,424
    15,029
    Sounds fine through my phone. :yesway:
  4. RCM 800
    RCM 800 Well-Known Member
    Dec 20, 2019
    874
    1,755
    I like it, unfortunately my work computer speakers arent great but sounds good.
  5. Australian
    Apr 20, 2009
    18,202
    10,191
    I've put another mix of it up. Which is better A or B? I think I like B better.
  6. Matthews Guitars
    3,575
    5,271
    Sounds good to me. Nicely balanced tone.
    You should get yourself one of these.
    Australian, RCM 800 and fitz288 like this.
  7. pedecamp
    16,424
    15,029
    Yeah B is better :yesway:
  8. SmokeyDopey
    Mar 9, 2011
    11,609
    7,397
    Argentina
    Hey Aus, it sounds cool, but I notice a bit of hiss. It isn't too overwhelming, but there is some. And on B it is accentuated a bit more (either because of compression or EQ or both).
    Having said that I also like B. Has a little more attack, and it has a little more clarity on the high-mids/top end.
  9. Australian
    Apr 20, 2009
    18,202
    10,191
    Yeah -The hiss is probably from the mixer . The faders were really high because I was using SM57 &SM58 mics at a distance. But I’m going to use a couple of tube mics and that should also get rid of that
    slight harsh mid that the D string is producing.
    I was hoping to make it easy with two dynamic mics, but they didnt quite make the grade.
    SmokeyDopey likes this.
  10. Australian
    Apr 20, 2009
    18,202
    10,191
    Segovia is turning in his grave. :spock:
  11. crossroadsnyc
    Feb 5, 2009
    21,301
    20,653
    It's such a beautiful piece, Aus ... honestly, I think you should refine it a bit. It's nice, but I know you can do better. What I do like, however, is the warmth ... if you can keep the warmth, but add a bit more clarity/attack, I think it would be pretty killer.
  12. Australian
    Apr 20, 2009
    18,202
    10,191
    Thanks. I’ll see what I can do. The rough edges wont be on the proper recording...hopefully. :)
  13. Australian
    Apr 20, 2009
    18,202
    10,191
    I've recorded the complete piece ('C' in the first post), and I think this is going to be the sound of the final proper recording, but played without flubs. Is it better than the other two, sound wise?
    tubes likes this.
  14. SmokeyDopey
    Mar 9, 2011
    11,609
    7,397
    Argentina
    Yeah, much better. The hiss dropped down significantly, and fuller sounding.
  15. SkyMonkey
    3,203
    4,227
    C is far better. The first two were somewhat distant.
  16. Australian
    Apr 20, 2009
    18,202
    10,191
    I used two Rode K2 mics instead of the dynamic mics . But the Problem was, for some reason the K2 mics dont work plugged straight into the Soundcraft mixer. I had to plug them into the Audio Interface instead. But I did end up mixing down back out through the mixer.
  17. Australian
    Apr 20, 2009
    18,202
    10,191
    I've just added another recording to the first post . Just some other snippets of some pieces that I play: Bach, Piazolla etc...
    Smokey, you'd be familiar with the Piazolla piece. :)
    SkyMonkey and SmokeyDopey like this.
  18. tubes
    tubes Well-Known Member
    Oct 25, 2009
    6,917
    3,871
    New Zealand
    First impressions and not over-thinking anything...
    Yep, the 'C' mix from the first post is the most friendly to my ears.
    And by 'ears' I mean something like: it is compressed on the internet, hearer has average sound card and average headphones.
    The 'C' mix is:
    Warmer
    More full of tones from all over the frequency range
    It has 'space': I mean, even with earphones I feel like I'm hearing something from some distance away.
    This last thing is important. Sometimes when a person records a single instrument it sounds too close, as if it were right next to my ear.
  19. SkyMonkey
    3,203
    4,227
    The new medley is quite something there @Australian.
    :ot: But this is one of my favourite 'Non-Classical' classical guitar pieces.
    The tones of the three guitars may be useful if you like it.
    tubes and Australian like this.
  20. Australian
    Apr 20, 2009
    18,202
    10,191
    That space is something I’ve been testing for a while, and trying to arrive at what I thought is musically listenable and sounds like my guitar does in the room. :yesway:
