Class 5 Power Tube Heat
Discussion in 'The Workbench' started by willyh, Sep 22, 2020.
  1. willyh
    willyh Active Member
    Feb 16, 2011
    173
    25
    Minneapolis MN
    I Just purchased Class 5 Head and Replaced Stock tubes with Vintage Glass. The PreAmp tubes came right out of the tube dampener But the power tube had melted rubber and was stuck. Is this normal? When I tried different Power tubes they seemed to get real hot right away. Head sounds great and does not apear to have any issues.
  2. Matthews Guitars
    2,705
    3,977
    Does the plate structure glow dull red when the amp has been on for a few minutes and you turn the room lights off? It should not. A glowing plate means the bias needs to be reset.
  3. willyh
    Feb 16, 2011
    173
    25
    Minneapolis MN
    I will check
  4. South Park
    2,997
    2,510
    The bias could be to high or the coupler caps are bad . The bias filter caps could be leaking .
  5. willyh
    Feb 16, 2011
    173
    25
    Minneapolis MN
    power tube looks about the same as preamp tubes as far as "glow"
  6. Gunner64
    Gunner64 Well-Known Member Gold Supporting Member
    Nov 16, 2013
    6,337
    8,291
    Midwest, USA
    They run hot, class A amp perhaps? and The bias is Non adjustable. If yours isn't redplating it's probably running as intended.
    The old boys used to call the 6bq5/El84 tube 6 barb-b-q 5 as they always ran hot.
  7. willyh
    Feb 16, 2011
    173
    25
    Minneapolis MN
    Yes that is what I found out. They make tube coolers that Hi Fi guys use. drops Temperature over 100 degrees. going to get one and take off damper on EL 84
