Chemtronics Soder-Wick
Discussion in 'The Workbench' started by CROWEMAG, Jul 16, 2020.
  1. CROWEMAG
    CROWEMAG Active Member
    May 22, 2018
    244
    128
    SO I have heard that this is THE stuff. I have some cheap wick at the moment and it is not an enjoyable experience.
    I am going to order some Chemtronics but am looking for some advice as to which exact version I should get for basic amp and pedal use. Thanks.
  2. MarshallDog
    Nov 28, 2010
    14,255
    14,942
    Taintville
    I prefer solder suckers over solder wick any day. Why, you dont have to heat the eyelet and trace as much which can cause damage. Just an FYI!
  3. Micky
    Apr 29, 2010
    20,982
    17,568
    Vermont
    Which solder wick depends on the size of the job.
    Generally I use 2-3mm but they make larger sizes for bigger jobs.
    Guitar-Rocker likes this.
  4. South Park
    2,666
    2,135
    You might not Be getting the Wick hot enough . Is the tip in good condition
  5. CROWEMAG
    May 22, 2018
    244
    128
    New tip on a nice Hakko iron. This is literally some cheap $2 junk. I do not think there is rosin in it.
  6. thetragichero
    Jun 6, 2010
    2,487
    634
    flo rida
    i buy the cheap stuff. less than a buck per thing. as long as it's shiny i have a tub of flux from ten years ago to dip it in
    that being said I've saved the empty container of techspray pro wick to add to the next order i place with someone who carries it
  7. MarshallDog
    Nov 28, 2010
    14,255
    14,942
    Taintville
    Thats probably what she said lol!
  8. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    724
    875
    Brooklyn, Joey!
    I learned a trick to sorta drag some wick thru my tin of flux- makes it work 10x better.
    Wick is better for cleaning up shitty globs of solder on old pots (sometimes) and supposedly preferred for using on printed boards which I don't ever plan on doing, but it could happen.
    thetragichero likes this.
