Can I use just one speaker in a two speaker amp?
Discussion in 'Marshall Amps' started by JCGdes, Oct 1, 2020.
  1. What?
    What? Well-Known Member
    May 17, 2018
    1,286
    1,113
    That is generally true, or it used to be. But it isn't absolutely true, depending on how the solid state amp is made. And now with class-d amps out there, who knows. Some solid state amps can be damaged with either no load or too low a load.
    Lance Chambers likes this.
  2. marshallmellowed
    Jun 26, 2009
    4,273
    5,946
    What? You'll have to be more specific, as in stating a specific example. Loosely stating something does not make it fact. I personally don't know of a solid state design, no matter what class (A/B, D...), that would be damaged by a no-load condition. Any amp can be damaged if overloaded (too little impedance), unless equipped with overload protection.
    Jethro Rocker likes this.
  3. Jethro Rocker
    9,220
    12,565
    Nope I have never heard of a SS amp that can be damaged with no load on it. The nature of the beast.
    No load equals infinite impedance. I also have a D amp that has no issues at all with no load.
  4. What?
    May 17, 2018
    1,286
    1,113
    How I understand it, some of the old solid state hifi amps, p.a. amps, and line amps used output transformers for their solid state designs and could get damaged by running without a load. Search on McIntosh for example. On solid state guitar amps specifically, I don't know of any.
  5. marshallmellowed
    Jun 26, 2009
    4,273
    5,946
    As far as I'm concerned, if you don't have specifics, it doesn't exist, and just adds confusion to the discussion, as we're discussing the OP's guitar amp.
  6. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    475
    560
    On the one speaker that still works but is sounding weird but still has resistance.....take it out lay it magnet down and carefully and evenly with two hands lightly push the cone in slightly(don't bottom it out)and let it come up by itself.....if it's stuck( it's shot)or if it scraps when you do this you have voice coil rub( fixable by a pro sometimes but not worth it unless it's a valuable vintage speaker)
    As for the two 12 amp.....if they are blown....why not just buy a couple used 12" celestion of the correct impedance and not try to mess with one???
    And another quick test is to touch a 1.5v( aaa aa c d)battery quickly across the speaker terminals and see if it makes a peep sound......sometines ohm meters act up.....make sure it's disconnected from the amp when you do this.
  7. Georgiatec
    Apr 23, 2010
    5,598
    5,114
    Blowing 3 speakers in two different amps in a short space of time is like lottery winning odds likely.
    I would certainly be looking at amp internal failures or operator error.
    John BNY likes this.
  8. SkyMonkey
    3,107
    4,094
    I have a 1997 Valvestate VS65R (i.e. SS with one preamp tube) that I ran accidentally without a load briefly.
    It happened when I took the chassis out to change the tube.
    I switched the amp on to test but forgot to connect the speaker.
    There was a curl of smoke and a bad smell.
    As soon as I noticed I switched the amp off.
    Once fully reconnected the amp worked fine.
    I was lucky.
    Not all SS amps are the same.
  9. John BNY
    John BNY Well-Known Member Silver Supporting Member
    Jul 13, 2013
    2,080
    3,285
    New York
    In the years I've been playing at high volume levels, I have never blown a speaker. As others have said, if the OP blew multiple speakers, there likely is a problem with the amp itself.
    Also, my understanding is that mismatching the impedance between the amp and speaker (at least in tube amps) will damage the amp and not the speaker. I've never heard of blowing a speaker from mismatching impedance. Then again, I never mismatch impedance, so I don't have any experience with what potential damage can come from mismatching.
  10. Jethro Rocker
    9,220
    12,565
    With SS the issues can occur with running lower than minimum impedance at high levels. There is no matching with SS, higher impedance simply means less volume.
  11. Jethro Rocker
    9,220
    12,565
    Even though there was smoke I disagree that the issue was running no load. If one did that with a tube amp, odds are slim it would puff smoke right away. If it did, it would not work again when turned on the second time.
    A SS should not puff smoke for that. Dunno what it was,,perhaps something burned on board but it still works?
    Manuals state not to go below 4 ohms. No speaker becomes an infinite load with SS. They do not have an output transformer. Other people with VS100 etc have run them without loads.
    SkyMonkey likes this.
  12. SkyMonkey
    3,107
    4,094
    I don't have the nous to explain it.
    No load = smoke.
    Load = happy amp.
    It happened immediately, and I switched it off within seconds.
    The VS65R has no minimum load statement in the manual or on the rear.
    I just assume 8 ohms is the minimum load due the the rating of the stock speaker.
    Also I am not willing to repeat the experiment, even in the name of science :noplease:
  13. MullardFillmore
    MullardFillmore New Member
    Nov 1, 2012
    21
    8
    If you use 1 speaker instead of 2, the wattage must be at least the combined wattage of the original 2 speakers. That’s playing it safe.
    You also need to have the correct impedance. If you had two 8 ohm speakers in parallel then that is 4 ohms. You will need one 4 ohm speaker.
    Technically, if your amp is set to 4 ohms you can use a speaker 4,8or 16 ohms. IOW the speaker must be equal or greater in impedance than what the amp is set to. These types of combinations will sound different due to reflections from the impedance mismatch.
  14. Lance Chambers
    Jun 23, 2019
    1,719
    2,747
    The Land That Time Forgot
    My GMX1200H modeler amp clearly states not to power on the amp without a speaker load connected.
    :drunk:
  15. yafal
    yafal New Member
    Feb 10, 2012
    25
    9
    Buenos Aires, Argentina
  16. Mrmadd
    Mrmadd Active Member
    Jul 29, 2020
    97
    154
    You can use a higher ohm load on an amp and not have any problem, ex 8ohm speaker on 4 ohm amp. Not the best thing to do, but you can get away with it.
    MG amps are notorius for pcb manufacturing issues that result in amp failures. These issues are not easy to find if you are not an experienced tech. I am not.
    It may be cheaper and way less issues to roll the dice and go to some place like GC used or Sam Ash used websites and just buy another
    amp. MG amps are kind of a dime a dozen at times.
    I have had a couple go bad, and just turned them into speaker cabs for heads that work. Some have worked out great.
    One thing to note, certain speakers are designed for certain amps and when mixing parts as such, your sound quality may suffer when you create a mis-match.
    Ex. MG 4 hole cabs are best suited for Marshall solid state amps. It is the same with the combos. I guess that is part of Marshall engineering.
    Good luck!
