Can I use a DSL1CR with a 2x12 or 4x12 cabinet?
Discussion in 'Marshall Amps' started by h1bda00, Oct 22, 2021.
Tags:
  1. h1bda00
    h1bda00 New Member
    Feb 19, 2021
    6
    9
    Hello,
    Just trying to understand if it's theoretically possible to safely connect my Marshall DSL1CR to a 2x12 or 4x12 cabinet. The DSL1 manual has the following:
    I thought the only thing that mattered (technically, I mean) is that the impedance of the speaker cab matches that of the amp, and that the amp's watts are not too powerful for the watt rating of the speakers.
    So for a 1 watt DSL1 with a 16 Ohm output jack, shouldn't I be able to connect to a 2x12 with 25 watt GBs as long as the total impedence of the cab is 16 Ohms? Why the limitation to a 1x16 Ohm?
    Any guidance would be appreciated.
    Thanks
  2. fitz288
    fitz288 Well-Known Yinzer Gold Supporting Member
    Apr 7, 2020
    4,162
    10,683
    the Burgh
    Hell yeah!
    It says 1 x 16 ohm speaker CABINET.
    Any 16 ohm cabinet and you're good to go.
    Should sound awesome through a 212 of greenbacks.
  3. h1bda00
    h1bda00 New Member
    Feb 19, 2021
    6
    9
    Right, thanks. I suppose that's what they mean.
    I would have written "only ever connect a single 16 Ohm speaker cabinet"
    For me, the " 1 x " implies a single speaker within that cabinet.
    Old Punker, PaulHikeS2 and fitz288 like this.
  4. fitz288
    Apr 7, 2020
    4,162
    10,683
    the Burgh
    Lot's of MFer's say they play the DSL1 through a 412.
    I used to run my DSL1H through two 10" 8 ohm cabs wired in series to 16 ohms.
    The transformer is just wired for 16 ohm output.
    There's actually an 8 ohm tap in there if you want to get into rewiring the little fella.
  5. PaulHikeS2
    PaulHikeS2 Well-Known Member Gold Supporting Member
    Aug 3, 2020
    589
    1,479
    I also run mine through two 10" 8 ohm cabs wired in series, but I never saw that disclaimer. If it explodes and I survive the blast, I'll post an update.
  6. Mitchell Pearrow
    15,720
    31,763
    As @fitz288 replied yes you can .
    As long as the impedance matches and you use a speaker cable you my friend are good to go.
    Cheers
    Mitch
    Old Punker, PelliX and fitz288 like this.
  7. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,595
    2,963
    I run my DSL (20, but same idea) through two cabs. Just make sure you balance the impedance correctly on the taps and it's fine. The "only ever connect 1 speaker/cab" thing is probably just a safety precaution as mixing cabs and impedances seems confusing to many people, so returns/complaints would increase.
  8. SkyMonkey
    3,828
    5,452
    It only has one 16 ohm speaker out.
    So they are trying to discourage splitters and series pairs of cabs in case something fails and the remaining impedance is a mismatch or just missing.
  9. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    1,559
    4,398
    Ontario, Canada
    My little 1W amp sounds better through a 2x12, again with impedances matched.
