Can a SV20 do Soundgarden style distortion?
Discussion in 'Marshall Amps' started by Mark Collier, Sep 14, 2021.
  1. Mark Collier
    Mark Collier Active Member
    Aug 8, 2019
    80
    177
    New Zealand
    I am on a Soundgarden and Metallica kick at the moment and can't seem to dial in the SV for a good Soundgarden, presuming I might struggle when I go for the Metallica one too.....
    Any suggestions on amp settings and/or a pedal in front that might work nicely?
  2. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    9,519
    8,419
    North
    I don’t have a SV 20 and have never tried to get their tone or even play any of their stuff (I like it) So looked this up. Kim used 2 Mesa’s
    That is the beginning of difficulty.
    Kim Thayil's Amps
    Kim combines a Mesa/Boogie Trem-o-Verb combo and a Mesa/Boogie Electradyne head dialed in to complement each other. The Trem-o-Verb is set quiet with a lot of gain and compression for the midrange and drive. The Electradyne is also set with a lot of gain but has more lows and more sparkle on the top end. The amps blend and run through two 4x12 cabinets with Celestion Vintage 30s for a full, complete sound. The Hughes & Kettner Rotosphere is run through the effects loop of the Electradyne, so there's one wet amp and one dry amp with the effect.”
  3. marshallmellowed
    Jun 26, 2009
    5,025
    7,871
  4. pedecamp
    17,647
    17,461
    Throw any OD pedal in front and dial it in. Their tone is nothing difficult just nice and heavy. :yesway:
  5. ibmorjamn
    Nov 3, 2012
    9,519
    8,419
    North
    Lots of people chasing Metallica tone.
  6. ibmorjamn
    Nov 3, 2012
    9,519
    8,419
    North
  7. gregr
    gregr Well-Known Member
    Jul 30, 2014
    467
    464
    One key part to Kim’s tone is lots low mids which I believe is out of the wheelhouse for the SV20. Mesas excel at this while being able to keep the tone super tight which is probably why he chose an Electra Dyne for that tour.
    It’s not ideal but with an SV20 you can do this with the bright channel and the right OD and an EQ in the loop. You can also use the normal channel with a good pedal. The Friedman Dirty Shirley is a good candidate.
  8. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    2,033
    2,632
    Södertälje, Sweden
    Early Soundgarden was Musicman amps.
    ibmorjamn, Mitchell Pearrow and gregr like this.
  9. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    1,178
    1,930
    Gonna need a dist pedal to get that dirty
    Remember all the studio effects added. Trying reviewing live sound clips. Obviously Big dif between live and studio. Id strive for their live sound first
    Old Punker and Mitchell Pearrow like this.
  10. Mitchell Pearrow
    14,962
    29,395
    Wow those are typically a very clean amp
    Old Punker likes this.
  11. FleshOnGear
    FleshOnGear Well-Known Member
    May 2, 2017
    551
    934
    Virginia
    When I think of Soundgarden tone, I think of Badmotorfinger, which was Peavey VTM amps. Their Mesa tones on later albums are really good, but not as distinctive IMO.
    How to do it on the SV20? You have to find the right pedal, but I don’t have any suggestions, unfortunately. I would play the pedal into the normal channel, and jumper it to the lower left input to add a little of the high treble into the mix.
    Mitchell Pearrow and Old Punker like this.
  12. Mark Collier
    Aug 8, 2019
    80
    177
    New Zealand
    Sweet suggestions thank you!
    I received a cheap Marshall Jackhammer by courier yesterday and just spent some time working with that.
    Holy hell that pedals EQ is vast. By moving fractions of millimeters on the pedal and nearly as small on the amp controls I got reasonably close. Just tiny turns and it was well out of the window, I'm actually a bit stunned how such small adjustments were required.
    The good news was I lost myself and blasted the neighbors for nearly an hour with the SV20 on full 20 watts through the PS1 on full (which I believe is half the actual volume) .
    Great fun. Now to focus on Metallica.
    I have a DOD Boneshaker pedal coming, hoping that will get close to that sound through the SV :)
  13. pedecamp
    17,647
    17,461
    Early Metallica was an 800 and a proco rat.
  14. Mark Collier
    Aug 8, 2019
    80
    177
    New Zealand
    Thank you, that just happens to be my default setting and that worked well with the Jackhammer pedal. Cheers.
  15. wolfpack
    wolfpack Active Member
    Jun 24, 2014
    131
    214
    Superunknown was recorded with blending an early 70s Marshall JMP50 and a Mesa Dual Rectifier
  16. Totengott666
    Totengott666 Member
    Sep 3, 2012
    36
    82
    It wasn't a 800, it was a modded SLP with a rat
  17. pedecamp
    17,647
    17,461
    Even better! :yesway:
