Buying new 4x4 speaker
Discussion in 'Cabinets & Speakers' started by bobbyvasco, Oct 26, 2021.
  1. bobbyvasco
    bobbyvasco Active Member
    Jan 13, 2017
    237
    48
    I am selling my old 1990 era 4x4 marshall cab because it is rattling, buzzing etc...and buying new one...I cant fix the buzz and it sounds really bad....
    I am running it through my JVM 410 so I need something strong and reliable
    so my first choice is
    Marshall MR1960 A which isI 300 w
    but there are other variations like
    Marshall MR1960 AV is 280 W so less then A
    Marshall MR1960 AX I like because of vintage speakers but is only 100W so what does it mean?
    Which one to buy?
    Mike Drop likes this.
  2. fitz288
    Apr 7, 2020
    3,588
    8,775
    rahndahbaht dah 'Burgh
  3. Mike Drop
    Mike Drop Well-Known Member
    Oct 23, 2021
    110
    335
    Let us know what you decide to get. I just bought a new MX412AR 240W cab. I'm waiting by the door.
  4. bobbyvasco
    Jan 13, 2017
    237
    48
    that seems to be the cheapest 4x4?
  5. Jethro Rocker
    10,120
    15,325
    Difference in the speakers inside. Don't get the 100 watt with the Greenbacks as your amp is 100 watts minimum at full.
    Look up the speakers in each of those cabs. Go to reviews. Look at Youtube. Even try one out and decide for yourself. Research...
    Geeze and fitz288 like this.
  6. Mike Drop
    Oct 23, 2021
    110
    335
    At a little over $500 US new, it seems reasonable for a Marshall box rated at 240w. I was also told the supply line for these has dried up.
  7. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    2,261
    4,254
    NH
    I wouldn’t ever buy a new 4x12 myself. There are at least a dozen used on CL within an hour drive of me right now.
    PelliX likes this.
  8. Matthews Guitars
    4,958
    7,425
    Any cabinet can be fixed. Your 4x12 (not 4x4, that should be parked in the driveway) probably has loose screws inside it.
    But I've seen cabinets where all the glue joints had failed. I have one that I had to rebuild. When I took it apart and stripped
    the tolex off it, I ended up with four loose boards that were the top, bottom, and sides that I had to clean and reglue to turn back into a cabinet.
    PelliX likes this.
  9. bobbyvasco
    Jan 13, 2017
    237
    48
    i have one myself JCM 900 which is same as 1960 cab and it rattles like crazy....
  10. bobbyvasco
    Jan 13, 2017
    237
    48
    i reglued back post...tightened all speakers...glued down handles....tightened posts where speakers sits on....and the clean sound is a disaster coming from this cab.....everybody says it is the amp...but I don't believe it because it was serviced...but in clean the guitar sound rattles like crazy etc when I hit low e string....
  11. fitz288
    Apr 7, 2020
    3,588
    8,775
  12. Matthews Guitars
    4,958
    7,425
    Bang on the cabinet with a rubber mallet. You'll hear it rattling if the rattling is coming from the cabinet.
    It can also help you find WHERE the problem is.
    Is it a model 1960 cabinet? Or what model?
    And where are you located? Just in case you're around the corner from me...
  13. bobbyvasco
    Jan 13, 2017
    237
    48
    europe buddy..it is quite far....ok I will try with a rubber mallet
  14. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    1,108
    1,296
    "tightened all speakers..."
    If you tightened all the speaker screws as tight as they can go, that might be the problem. That can warp the speaker baskets and cause voice coil rub, which sometimes can be heard as a rattle, buzz, growl on low clean notes. (It's still there with distortion but it's harder to pick out -- can just sound like ugly distortion.)
    Speaker screws should be barely snug, not tightened all the way.
    I'm under the impression you bought the cab used. If so a previous owner may have overtightened the screws enough to cause the problems and you should have loosened them a little instead of tightening them even more.
  15. bobbyvasco
    Jan 13, 2017
    237
    48
    I banged on the cabinet....I cant figure out where it comes from.....
    how do I know if it comes from speaker itself?
  16. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,995
    3,425
    Remove both handles and take it for a dry run..
    Also, if original Celestion speakers, they should have the paper bushings intact around the frame.
  17. bobbyvasco
    Jan 13, 2017
    237
    48
    the most vibrates is the back plate....that is screwed down...I even put a cloth between back post and rear back plate.....but still it vibrates in special notes on lower E string
  18. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    1,338
    3,150
    Check the wire routing and make sure they're free and have plenty of room and not up against something.
  19. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    9,211
    5,193
    Lakeland, TN
    If the spider comes loose on one speaker(or more) it could cause a rattle. I had a vintage G12-80 that sounds OK at lower distorted volumes.
    But if played clean it would rattle...if played loudly, it would rattle. Then I dropped it on the way to get repaired bending the frame some,
    but my speaker guy fixed both issues and it was good to go.
  20. bobbyvasco
    Jan 13, 2017
    237
    48
    what is spider
