Build your own amp: use 6x ECC83
Discussion in 'The Workbench' started by StingRay85, Oct 21, 2021.
  1. StingRay85
    StingRay85 Well-Known Member
    Aug 18, 2019
    1,785
    1,377
    How would you use them?
    - Let's say 1 goes to LTP PI
    - 1 goes to tube buffered FX loop
    Still 8 triodes left.
    Two channels. If you mix them after 1 gain stage, there's 1 ECC83 gone and still 3 to use.
    Or why not blend them after the second stage? That adds one ECC83 and still 2 to use.
    But what if you want separate tone stacks for the channels, driven by cathode follower, and only mix them after the recovery stage???
    We are getting close now.... 6 might not even cut it. It's decided, we need at least 7 ECC83 ;)
    But what would you do if you could go nuts with tubes? I have a Acoustic 330 solid state two channel amp, and the nicest sounds can be obtained by blending the two channels when using a combination of extreme settings. Like complete mid cut and treble and bass maxed out, blended with a more overdriven but flatter EQ response
  2. Pete Farrington
    Jan 18, 2021
    726
    709
    Staffordshire UK
    An fx loop recovery stage? So separate fx loops for each channel?
  3. StingRay85
    Aug 18, 2019
    1,785
    1,377
    Hmm... No that's too extreme I reckon. Let me think
  4. thetragichero
    Jun 6, 2010
    3,346
    1,300
    flo rida
    that's a lot of little bottles unless you're trying to implement a harmonic tremolo or something 12au7s/12bh7s between the phase inverter and output stage may be of some use (check various svt schematics)
    depending on what you've got in the power section
    the more i play and build the more i'm settling on a 'less is more' philosophy
  5. _Steve
    _Steve Well-Known Member
    Apr 29, 2020
    528
    442
    Maybe a directly-coupled CF/buffer driver for the power tubes.
    I've been wanting to try one for a while..
  6. StingRay85
    Aug 18, 2019
    1,785
    1,377
    Do you have a schematic for that?
  7. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    9,952
    9,246
    North
    Would you be able to use 2 tubes as a power section? I ask and I kind of know , to much gain for power tubes. Makes me wonder ?
  8. StingRay85
    Aug 18, 2019
    1,785
    1,377
    For power I have 4x EL34.
    ibmorjamn likes this.
  9. Dogs of Doom
    26,107
    34,133
  10. Matthews Guitars
    4,975
    7,460
    Lots of Fender amps have six preamp tubes with reverb and tremolo.
    Or you could go with a four gain stage lead channel like in a Mesa Mark IIC+.
    Stephen H likes this.
  11. _Steve
    Apr 29, 2020
    528
    442
    The most famous is the Ampeg SVT with 12BH7s, but im pretty sure you can also do it with 12AU7s. I think HiFi guys use them..
    StingRay85 likes this.
  12. XTRXTR
    XTRXTR Well-Known Member
    Feb 14, 2021
    382
    336
    You could try to build a Chorus using a bunch of triodes...no IC or transistors. That might be cool to try actually.
  13. StingRay85
    Aug 18, 2019
    1,785
    1,377
    Cool. I have a pair of 12BH7 in my stash so worth a try
  14. fitz288
    Apr 7, 2020
    3,650
    8,985
    rahndahbaht dah 'Burgh
    6100 has 6 preamp tubes + PI.
    High gain channel uses 4 of them.
    Pete Farrington likes this.
  15. Pete Farrington
    Jan 18, 2021
    726
    709
    Staffordshire UK
    Yes, a series of DCCFs in cascade, that makes short work of utilising all those valves!
    Stephen H and fitz288 like this.
  16. StingRay85
    Aug 18, 2019
    1,785
    1,377
    6100 is a respectabele amp isn't it?
    fitz288 likes this.
  17. Pete Farrington
    Jan 18, 2021
    726
    709
    Staffordshire UK
    Certainly, a friend had one for a while, so I got to know it fairly well, thankfully didn’t have to fix anything though. He eventually traded it for a Mesa MKIV for more of a fusion thing, but it was a sideways move, rather than an upgrade.
    fitz288 likes this.
  18. fitz288
    Apr 7, 2020
    3,650
    8,985
    I love my 6101, but not everyone feels the same way.
    Gut shot looks like a computer, not sure how it translates to a home build.
    Have you looked at some of @NewReligion 's gain mods to a classic circuit?
    NewReligion likes this.
  19. StingRay85
    Aug 18, 2019
    1,785
    1,377
    No I havent. But the concepts to increase overdrive are more or less clear to me
  20. NewReligion
    Nov 17, 2009
    11,657
    9,044
    Paradise
    Reverse engineer the preamp (dirty side if multi channel) draw it out. Then apply what you know or experiment. Tone Stacks are fun too.
    Good luck.
    David Hopkins a.k.a. @NewReligion
