Bright cap voltage value
Discussion in 'The Workbench' started by Dominic Lampron, Sep 22, 2020.
  1. Dominic Lampron
    Dominic Lampron Member
    Feb 2, 2020
    121
    2
    Hi. What is the voltage value of the 1nf bright cap on the gain pot of a 2203 JMP 100W? Thanks
  2. neikeel
    4,736
    3,142
    It can be quite low (250v) but I use 1kV ceramic disc as they are correct size
    Dominic Lampron likes this.
  3. thetragichero
    Jun 6, 2010
    2,673
    774
    flo rida
    a lot of things have to go wrong for that cap to see more than a couple hundred volts
    but as mentioned, size and lead thickness (especially in resistors) often make overspeced components a good choice
  4. Dominic Lampron
    Feb 2, 2020
    121
    2
    Thanks Neikeel! Do you have brand to recommand? It's for taming my 2203, quite a lot bright to me ears! I've pull off the bright cap, but maybe to have a lower value on this will make a good blend! I've also mods the tone stack values (56K/220pf), much better, but still bright. I'll try to figure out with the TSC what can i do more in that part to have a better tone. I'll check to drop a bit the HF cap value (maybe around 120pf) and change the mid cap(22nf) by a lower one (between 12nf and 18nf), i'll have to try. But on the TSC, the mids response seem to be very cool with those values. I'll try! Thanks again!
  5. Dominic Lampron
    Feb 2, 2020
    121
    2
    thanks!
  6. anitoli
    8,509
    10,820
    Are you playing by yourself or with a band?
  7. Dominic Lampron
    Feb 2, 2020
    121
    2
    Both.
