Boss dd3 not working in 6100 Loop
Discussion in 'Marshall Amps' started by [email protected], Jan 17, 2021.
  1. jamesavannoy@yahoo.com
    [email protected] New Member
    Feb 23, 2009
    4
    Hello,
    I am having issues running my boss dd-3 into the loop of my 6100. The pedal keeps washing out, as if the signal is too hot.
    I have tried the all the combinations with the Line level button and switched back between Parallel and Series with luck
    I know it is not the pedal, as I have tried 2 separate pedals with the same results.
  2. The Dose of Harmony
    The Dose of Harmony Well-Known Member Gold Supporting Member
    Nov 21, 2014
    826
    1,007
    Washing out? What the fuck Does that mean?
    1. Which loop are you using?
    2. There is two pot shafts to adjust the level from -10 to + 4?
    3. Level of the pedal?
  3. anitoli
    9,229
    12,261
    Channel 3 is the default loop level in the series/parallel loop. There are two trim pots to adjust the levels for channels 1&2. Remember to use parallel the effects knob needs to be fully clockwise and fully counter clockwise for series.
    Are you using a noise gate?
    Jethro Rocker likes this.
