Boss Dd# In Loop Of 6100
ceremony5150
Can anyone let me know the ideal way to set up Boss Pedals in the loop of a 6100?
anitoli
For time based FX, run the loop series, FX knob fully clockwise, you may need to play with the DB switch on the back to see what level the pedals like better.
Phony iommi
When you suggest run the fx knob fully clockwise do you mean the level on the effect pedal itself or on the trip pot on the back of the head?
anitoli
Neither. Adjust the fx trim pots so channel 1 & 2's level matches that of the default channel three. Adjust the fx knob on the pedal to taste and turn the front panel knob fully clockwise. An easy way to check if the loop is in series is to turn the fx knob ccw and if you still have sound you are in parallel.
