SmokestackElRopo
- Joined
- Jan 7, 2008
- Messages
- 506
- Reaction score
- 201
N 2011 I purchased a VM 2266C @ Sweetwater. I was gonna get a Bluesbreaker, I can find no comparisons. Didn't need tremolo. Is there that much difference?
Um, you have a JTM45?N 2011 I purchased a VM 2266C @ Sweetwater. I was gonna get a Bluesbreaker, I can find no comparisons. Didn't need tremolo. Is there that much difference?
I do not have any personal experience. However, this from Steve Dawson, the designer of the VM.
"The Vintage Modern is basically a JTM45 with some hot rodding. For a JTM 45 tone select the low dynamic range, master volume on full, mid boost out, Detail at 2 -4 o'clock. Body at 1 - 3 o'clock and then dime the tones. This should be very close. I developed the Vintage Modern from the Super100JH I did before it. A hot rodded JTM45 period amp is quite rare so it seemed like a good idea to make it available to the public."
they are two totally different circuits ..bluesbreaker is primarily a marshall jtm 45 4 inputs and u can jump the channels blending 2 together ..this is what clapton and many others use, past and present. A vintage modern is a much new circuit single channel amp with a master volume which is good if you want that really overdriven sound at a lower volume..i'm not sure where the VM 2266c is manufactured?? me personally i only prefer the ones made in England..typically the pcb inside are thicker and not imported if that makes a difference to you..best luck..N 2011 I purchased a VM 2266C @ Sweetwater. I was gonna get a Bluesbreaker, I can find no comparisons. Didn't need tremolo. Is there that much difference?
its England made probably there best since the 800 most agreethey are two totally different circuits ..bluesbreaker is primarily a marshall jtm 45 4 inputs and u can jump the channels blending 2 together ..this is what clapton and many others use, past and present. A vintage modern is a much new circuit single channel amp with a master volume which is good if you want that really overdriven sound at a lower volume..i'm not sure where the VM 2266c is manufactured?? me personally i only prefer the ones made in England..typically the pcb inside are thicker and not imported if that makes a difference to you..best luck..
p.s a non master volume amp like the bluesbreaker, you can always use a nice overdrive/distortin pedal..and get killer sound..thats what i do
On the VM circuit, the guy who actually designed it says different.This from Steve Dawson, the designer of the VM.they are two totally different circuits ..bluesbreaker is primarily a marshall jtm 45 4 inputs and u can jump the channels blending 2 together ..this is what clapton and many others use, past and present. A vintage modern is a much new circuit single channel amp with a master volume which is good if you want that really overdriven sound at a lower volume..i'm not sure where the VM 2266c is manufactured?? me personally i only prefer the ones made in England..typically the pcb inside are thicker and not imported if that makes a difference to you..best luck..
"The Vintage Modern is basically a JTM45 with some hot rodding...."
He added an extra switchable gain stage, added the Master Volume, added an fx loop and configured the input circuitry to blend hi and lo with pots from a single input instead of 4. Also an SS rectifier. But, if you set it at max and switch out the extra stage, the idea is it's very JTM45.
thats what i thought..it sounds like a great amp...i remember a long time ago an early jtm45 head i had..i change to output rectifier to a solid state rectifier, it seemed to give it a lil more uummff ..stay rockinOn the VM circuit, the guy who actually designed it says different.This from Steve Dawson, the designer of the VM.
Yes, I have a JTM45 and a VM. The JTM has its own voice. Played thru a JCM 900 1936 w/2 redfangs, it will not sound like a Bluesbreaker.
