Big M Cabinet
Discussion in 'Cabinets & Speakers' started by Snake321, Oct 11, 2021.
  1. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Just got a Big M cab model M2212f.
    I know it was assembled in L.I.
    I've read the whole deal.
    Its a vertical 2 x 12 with folded sides.
    A bass player previously owned it, it could be bass or organ.
    Strange part is there is obviously 2 different speakers inside.
    One shiny, one not.
    Easy to say one was changed, but....
    The back has nice tolerance completely covering the back, no seam to open the cover.
    Then there's no visible screws.
    Anybody seen this before?
  2. Dogs of Doom
    26,367
    35,002
    I posted a thread, asking about these:
    '70s Big M 2x12?
    It seems the front baffle unscrews...
  3. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    1,127
    1,347
    If it's like this one from the other thread, the grille cloth frame is attached to the cab with Velcro -- 3 tabs on the left edge and 3 tabs on the right edge.
    Use a thin screwdriver, putty knife, church key bottle/can opener, or something similar. Work in in around the edges and pry the frame away from the cab, being cautious not to dent the lip of the cab.
    It'll make the scary Velcro "ripping" sound. Once you get a corner or edge loose enough to get your fingers under the frame just pull it the rest of the way off.
    jmp45 and Dogs of Doom like this.
  4. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Thanks guys.
    I'll give it a try tonite.
    I see the m2x12 mentioned.
    This is m2212
  5. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
  6. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
  7. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Says my pics are too large
  8. Dogs of Doom
    26,367
    35,002
    they need to be resized to under 1MB in size...
  9. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    3,278
    3,907
    75/76? (contracted) Eminance speakers. (curious if it has a plywood soundpost)
  10. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,972
    4,183
    Im surprised they didn't point the speakers the other way to lengthen the sound travel - an old HiFi trick even in the 60's.
    Russ
    jmp45 likes this.
  11. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    I'll resize the pics today.
    Box is nice, 3/4 plywood, folded sides are partical board. I've read bad stuff about the big M, but this is a nice cab.
    Any ideas on that model number?
  12. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Theres 1
  13. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Nice grill
  14. RLW59
    Nov 30, 2017
    1,127
    1,347
    Model number -- no one really knows. The cab in the other thread didn't have its model number tag so people just called it an M2x12.
    The aluminum cone speaker in yours is definitely a replacement since those didn't exist in the mid '70s. While Hartke is most associated with aluminum cones, Behringer has also used them and there are some "generic" versions too.
    Your baffle has 8 mounting screws for each speaker (instead of 4 each like the cab in the other thread), so the other speaker may also be a replacement. Many bass speakers have heavy cast frames and huge magnets and 4 mounting screws is marginal with mdf/particle board.
    Dogs of Doom likes this.
  15. Dogs of Doom
    26,367
    35,002
    someone thought that the baffle in the other one might have been a replacement, because the 11" speaker holes didn't seem to be factory cut, but hand sawn...
    junk notes likes this.
  16. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Both replacement speakers
  17. Dogs of Doom
    26,367
    35,002
    I bet that thing's heavy...
  18. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    It is, ill weigh it.
    Tonite its going up 2 flights of stairs.
    I have 2 70 celestions ill put in it and try her out
    VERVEHAMMER likes this.
  19. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
    Its going in the bottom center to replace the anniversary cab.
    Its a slant, has no business down there
    fitz288 likes this.
  20. Snake321
    Snake321 New Member
    Oct 11, 2021
    22
    14
