Biasing voltage drop. Check my numbers
Discussion in 'The Workbench' started by Joshabr1, Oct 23, 2021.
  1. Joshabr1
    Joshabr1 Well-Known Member
    Sep 2, 2013
    1,466
    687
    Ky
    Plate voltage 481
    v4/5 17.2ohms //// .520 voltage drop
    v6/7 15.5ohms//// .550 voltage drop
    so 17.2/.520 and 15.5/.550
  2. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    So I get v4/5 = 33.07
    v6/7=28.18
  3. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    If my math is correct I’m happy with these numbers. Right? Been a while several years actually since I done this method. So thanks for the help
  4. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    So for 65% dissipation I’m looking for 33ma
    so .033* 17.2 = .562 so I keep my voltage drop under .562 correct???
  5. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    Anyone in the good ole USA awake tonight??
  6. thetragichero
    Jun 6, 2010
    3,346
    1,300
    flo rida
  7. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    Well. That is
    So can you look at the numbers above and answer my question ? Am I doing it right??
  8. thetragichero
    Jun 6, 2010
    3,346
    1,300
    flo rida
    voltage drop of 520mV across a 17.2 ohm resistance is 30.2mA, but if this is for a pair of tubes that's 15.2mA per tube so assuming a 25w max plate dissipation that's 29.1% of max plate dissipation at idle
  9. Joshabr1
    Sep 2, 2013
    1,466
    687
    Ky
    So what is the math for my superbass. That’s what I am asking
  10. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    832
    713
    If it's a 4 cylinder SB you need 2 x .562 = 1.12
    My SB, 14.9 ohm and 16.3 ohm, & 490DCV plate divide 17.5 dis = .035 x 2 = .070
    .070 x 14.9 ohm = 1.14 pin 3 to C tap.
    Joshabr1 likes this.
  11. mickeydg5
    mickeydg5 Well-Known Member
    26,779
    13,961
    united States of America
    Sorry I did not see your message until now.
    Your math is fine. Always do it twice, double check.
    From above this is a Super Bass, model 1992 100W output amplifier.
    So that is four power tubes, two tubes on each side of the push-pull.
    .520 / 17.2 = 30.2mA, basically 15.1mA per tube >That is low
    .550 / 15.5 = 35.4mA, basically 17.7mA per tube >That is low
    Now with about 480VDC on the power tube plates then this amplifier should have more like average bias of 72mA and maximum bias current of 84mA.
    When your up the bias the plate voltage may drop so recalculate as necessary.
    I know this may have all been hashed through already but I will reiterate. :)
  12. neikeel
    6,440
    5,350
    We’ve done all this by pm some days ago:(
    mickeydg5 likes this.
  13. Matthews Guitars
    4,975
    7,460
    I just install precision 1.00 ohm resistors between pins 1,8 and ground and direct read the bias current off them. The mV reading across them equals the mA current through them. No messing with calculations.
    mickeydg5 and thetragichero like this.
  14. mickeydg5
    26,779
    13,961
    If I do not have the 1 ohm bias resistors then I use the OT calculation method.
  15. Matthews Guitars
    4,975
    7,460
    I ordered up a bag of 100 of those resistors. I don't expect to run out this year or next year either.
