Silverburst
- Joined
- May 12, 2009
- Messages
- 883
- Reaction score
- 355
I finally found the culprit with a fresh mind this morning!
For the sale of future problems other members might come across, here are my notes of my n00b amp mind going through the process lol: As @Pete Farrington mentioned, check voltages and where it is off in fault mode it should be easy to find. So i figured (it is the first time I went through this more in depth amp diagnostics exercise
): well then indeed the heater voltage is not getting into that V4a triode, resulting in missing voltage amplification (188v in stead of 306v in working mode) in that triode. The tube visually seemed to word fine because the other triode was lighting up. So I started wiggling the heather wire specifically and it revealed an oddly movement on pin 4!
jup, a loose solder joint, like a needle in a haystack for a rookie amp tech. I could perfectly recreate the effect now just with that pin 4 contact, which of course now just makes perfect sense hindsight. Check the hidden MF-er!
Now that this is in my brains visual library, it is gonna help me to spot these things faster in the future. But this has been a very good exercise for my so far. No way better than getting out your DMM and dive in there (safely! draining filter caps, or while amp enabled one hand in my pocket).
I'm a bit proud here lol
Thanks for all your help and patience!
