Silverburst
- Joined
- May 12, 2009
- Messages
- 880
- Reaction score
- 351
Hi all,
Went to get this 2205 for a good price because it had some issues.
While testing the amp at the seller's house, it had some hum from the start but within a minute the hum became very loud with a lot of rrrr-sound, which reminded me of the sound I once had with a power tube that was failing. I found the EL34B's tubes were glowing quite a bit, so we shut down the amp and I decided to take it home for a good price.
At home a few days later the amp played again quite fine with a bit of hum but again after a few minutes the hum suddenly became a lot worse with some seriously loud squeaks, so I shut it down immediately. Afterwards when restarting it, no sound at all. I noticed the HT fuse had blown. So I assumed a power tube had died on me during that heart attack sound a few minutes ago.
Took it to my bench and opened it up. I noticed the Bias resistors had been tempered with, but the guy claimed it had run fine for years. Pics and values in post below (Tech note on the inside mentioned new tubes in 2015 and a preamp socket replaced, but I don't think the amp was played that much)
I replaced the HT fuse, put another set of EL34B's I happen to have in there, turned the Bias pot all the way up to get maximum negative voltage and to start I did some measurements with a 1ohm tube probe socket:
EDIT: NOW HAVING VOLUME TROUBLES
- EDIT SOLVED WITH NEW TUBES +/- 300 mA's across the cathode, like 10x too much! I didn't dare to let it settle to avoid damaging the new tubes so shut it down immediately. Neither did I dare to test the other socket in this condition. UPDATE: I tested the other socket and 2nd tube. Both sockets same behavior. 2nd tubes goes up to about 220 mV's thus 220 mA's.
- pin 5 voltage on both sockets, ranging between -36v to -44v when dialing Bias pot from min to max.
- Pin 3 voltage on both sockets = 462v after a few minutes.
- Resistors Pin4-6 on both socket still 1000 Ohm
- Filter cap 1: leg 1 328v and leg 2 378v Filter cap 2: 455v both legs
