Bias Probe - What To Get?
Discussion in 'The Workbench' started by pedecamp, Sep 17, 2013.
  1. pedecamp
    18,336
    18,928
    Some have meters, some don't, some have switch boxes, etc. The first one is highly recommended by some of the members here, but I see there's so many different ones to choose. What to get and why?
  2. Micky
    Apr 29, 2010
    21,154
    17,906
    Vermont
    For others it may depend on the amp, but I always use a multimeter.
    NewReligion likes this.
  3. chuckharmonjr
    Mar 26, 2010
    8,819
    4,326
    a 1 ohm resistor, a soldering iron (once) and a multi-meter that reads milli-amps
    Micky likes this.
  4. pedecamp
    18,336
    18,928
    Chuck youre gonna have to elaborate on that one, I'm not sure what you mean.
  5. bulldozer1984
    bulldozer1984 Everybody's Favorite Member VIP Member
    Aug 29, 2010
    7,814
    4,710
    Sydney..
    A 1 ohm resistor is basically all that is inside these probes and if you can solder and work on amps safely then you can do very cheaply..
    Personally i like probes and I have the first probe you posted. Works great. I would not buy those - cheap made in China - pieces of junk.
    aw9190 and pedecamp like this.
  6. chuckharmonjr
    Mar 26, 2010
    8,819
    4,326
    Insert a 1/2 watt, 1 ohm resistor in the bias feed in series. In other words, lift the wire from the power tube pin, solder the resistor there then solder the wire to the other side of the resistor. You have now created a millivolt shunt in the line. Set your multi meter to millivolts, read across the resistor and you have what the bias current draw is in milliamps.
    chee16 and pedecamp like this.
  7. pedecamp
    18,336
    18,928
    Yeah, whatever I get I want it American made. Probably will get the one you have.
  8. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,635
    4,203
    Austin TX
    I have the Amp Head probes (EL84 as well), I like them. Mine are the more basic ones without the plate voltage switch.
  9. aw9190
    aw9190 Active Member
    Jun 15, 2011
    357
    64
    Staten Island, NY
    i have the amp head probe as well. Great tool really, i have the one that gives me plate voltage which is very useful.
  10. brp
    brp Well-Known Member
    Nov 11, 2010
    5,265
    2,847
    Vancouver, Canada
    I need to get one of these too. Hopefully in Canada but I will go to the amp head site ebay if necessary.
    Any of my Canadian bros. know where to get a good one here in Canada?
  11. anitoli
    10,467
    15,377
    Read this:
    Bias FAQ
    Unless your meter shows plate voltage no milliamp reading will tell you proper dissipation.
    V x I = P
    For example, 465V x 35ma (.035) = 16.2W.
    Read the article and you will be on your way to properly biasing your amp.
    Ill be honest i dont like those probe things at all. 4 resistors and a multi meter is all you need.
    Roger Tyria likes this.
  12. pedecamp
    18,336
    18,928
    My bias probe showed up today. Popped in my tubes and bias probe in the amp, took a plate voltage reading and got 380 if I did it right, so according to my calculations 70% dissipation I need to set bias at 38mA. Checked the bias on each tube, got 61 on the left and 59 on the right, so lowered left to 38, checked right which measured at 36. So if I raise the right to 38 the left will be at 40. Is my goal to make both sides match or just split the difference between the two, set left at 39 and right 37 since I cant make both match?
  13. Micky
    Apr 29, 2010
    21,154
    17,906
    Vermont
    Get them as close as possible.
    I think bias specs say plus or minus 5%, so a couple ma isn't gonna matter that much as long as they are as close as possible.
    pedecamp likes this.
  14. MartyStrat54
    Feb 21, 2009
    26,014
    9,606
    Licksville
    Exactly. They won't be identical readouts. The circuits would have to be perfect and the power tubes identical. Ain't gonna happen.
    Also, a trick is to swap the tubes and sometimes this will yield a closer bias match.
  15. pedecamp
    18,336
    18,928
    They're only off by 2mA from each other, so I'm good to go? I'll just split the difference the best I can, set one at 39 and the other 37?
  16. pedecamp
    18,336
    18,928
    Thanks David!
  17. NewReligion
    Nov 17, 2009
    11,688
    9,122
    Paradise
    Sounds like you have figured out bro. The bias may drift a bit with time too as the tubes get older and burn in. This can all seem a little overwhelming at times with so much information available and techniques. I too use a bias probe and multimeter then usually run my tubes between 60%-70% dissipation.
    I go so far as to record all of my findings right down to which tube in what amp at a specific location. This too aids me in being able to mix and match sets as I see fit (like yubes).
    If you have any additional specific questions you are welcome to PM me and I will address your questions to the best of my knowledge.
    Respectfully, David ♫
    MartyStrat54 and pedecamp like this.
  18. pedecamp
    18,336
    18,928
    The 2204 sounds good, nice and crunchy and open sounding with the Winged =C=. Maybe tomorrow I'll try the GT-EL34M and the JJ KT77 in there and see what I like best. Thanks for everybody's help figuring out how to work this thing. :thumb:
  19. MartyStrat54
    Feb 21, 2009
    26,014
    9,606
    Licksville
    You'll be a pro by tomorrow.
  20. tazzboy
    tazzboy Well-Known Member
    Oct 1, 2007
    894
    304
    Oregon
    Get a Ted Weber Bias Rite Probe they are worth the money.
