Bias Probe - what to get? (2021 edition)
Discussion in 'The Workbench' started by Benighted, Oct 19, 2021.
  1. Benighted
    Benighted Member
    Sep 30, 2020
    74
    76
    Illinois
    This is a continuation of an older thread (below).
    https://www.marshallforum.com/threads/bias-probe-what-to-get.61179/
    Most of the probes recommended back then are no longer available (Weber, amp-head). Also, the few good ones remaining are back-ordered (Eurotubes Pro One).
    There are couple Chinese ones on ebay, but they either lack reviews or their reviews are bad.
    So, what would you guys recommend?
    Thanks
    fitz288 likes this.
  2. don550
    don550 Member
    May 28, 2019
    52
    97
    Southern California
    Ray Baker and Benighted like this.
  3. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    3,001
    2,915
    For now you could just use the 1ohm resistor and voltmeter method that many of us use. What amp and power tubes are we talking about?
    Take a look at the way Ceriatone adds 1ohm resistors from the power tubes to ports on the back of the amp. You don’t have to be that fancy, just run the resistors to ground. You read the Mv across the resistor and that is pretty close to what the bias is.
    http://www.ceriatone.com/ceriatone/wp-content/uploads/2016/09/JCM800_2204Ceriatone.jpg
    Benighted likes this.
  4. RobS
    RobS Well-Known Member
    Apr 19, 2009
    1,033
    351
    Melbourne - Australia
    agree with Chris above in using 10hm resistors.
    Plus the resistors act as a fuse should something go wrong & are more accurate than the plug in probes
  5. Benighted
    Benighted Member
    Sep 30, 2020
    74
    76
    Illinois
    The amp is JVM410h/ 4xEL34
  6. pedecamp
    18,383
    19,063
    I would think anywhere that sells tubes sells bias probes. Look around and see whats out there.
  7. Chris-in-LA
    Jul 19, 2018
    3,001
    2,915
  8. fitz288
    fitz288 Well-Known Yinzer Gold Supporting Member
    Apr 7, 2020
    4,160
    10,682
    the Burgh
    I have the Eurotubes probes, they work great.
    Bias Probes and Multimeters - Eurotubes
    I got a Pro One with the watts option and a basic octal probe that hooks to my meter.
    Can do 2 tubes at a time and dial in the bias settings for a pair.
    don550, Benighted and Ray Baker like this.
  9. KraftyBob
    Sep 5, 2017
    2,028
    2,710
    Chicago Suburbs - USA
  10. scotheath
    scotheath Active Member
    Oct 24, 2015
    133
    70
    Provost AB
    Exactly the same set up I'm using, yes those sockets are a tight fit
    Benighted and KraftyBob like this.
  11. _Steve
    _Steve Well-Known Member
    Apr 29, 2020
    545
    458
    Unfortunately these are backordered too, but good to know about thanks.
    Any others on the market that do both plate voltage and k current?
    KraftyBob likes this.
  12. KraftyBob
    Sep 5, 2017
    2,028
    2,710
    If you click on "Technical Documentation" about half way down the page there's a link for the Bias Scout Assembly instructions including the parts list. Perhaps you can source the components yourself and built them?
  13. fitz288
    Apr 7, 2020
    4,160
    10,682
    the Burgh
  14. anitoli
    10,474
    15,415
    The HJS has the internal bias pins not sure about the 410h.
  15. Benighted
    Benighted Member
    Sep 30, 2020
    74
    76
    Illinois
    I considered these, but Nobsound probes have very low rating on Amazon. It looks eurotubes probe is the only quality alternative that is readily available.
    fitz288 likes this.
  16. cozmacozmy
    cozmacozmy Active Member
    Apr 9, 2011
    131
    79
    West Michigan
    VERVEHAMMER and Benighted like this.
