Best type of resistor to use?
Discussion in 'The Workbench' started by JM5010, Aug 12, 2020.
  1. JM5010
    JM5010 Active Member
    Nov 11, 2017
    279
    47
    What is the best type of resistor to use in Marshall amps?
    Specifically, what is best to use for: the plates, the cathodes, voltage dropping, etc...
    I'm not talking about wattage, just the composition!
    Edit: What types of resistors did Marshall use in the 70's?
    Shawn Kawvey likes this.
  2. mickeydg5
    mickeydg5 Well-Known Member
    25,059
    12,022
    People like different composition for different use.
    I think it is mostly limited to carbon types used in signal chain events. The same goes for different composition of capacitors.
    Shawn Kawvey and JM5010 like this.
  3. JM5010
    Nov 11, 2017
    279
    47
    Hmm let me get specific. What would you use in a high gain build?
  4. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    473
    388
    60's Piher film and ABradley comp, 70' Iskra film then later back to Piher.
    On a build I would use Piher, only because I don't have many Iskra.
  5. neikeel
    4,722
    3,132
    Good advice here:
    http://www.aikenamps.com/index.php/technical-q-a
    In a true high gain build I would use metal film in most spots, flame proof metal oxide as droppers/decouplers in teh B+ line. Having said that for most normal builds decent quality carbon film are fine and hi-gain is not typically my genre but I do like amps that are dead quiet when you are not injecting signal. New builds I still use Xicon 1w and in clones, restos I like the Pihers. For true restorations I would use Iskra or Piher depending on what has been removed/being replaced. will occasionally use a carbon comp but they do drift and get noisy (aka vintage warmth which can = irritating hiss or crackle depending on you perspective). My son is currently prepping for a x4 KT120 bass amp and it is a relatively simple set up so might try something exotic from the Hifi world like Kiwame or Takman but may still just go for the Vishay CCF60 metal film which sound ideal.
    Look at some of the builds by FourT6and2 and others.
    JM5010 and Shawn Kawvey like this.
  6. thetragichero
    Jun 6, 2010
    2,660
    758
    flo rida
    i try to use 2w metal oxide resistors pretty much everywhere besides on the input (metal film there)
    JM5010 likes this.
  7. Guitar-Rocker
    Mar 5, 2012
    2,832
    2,475
    Indianapolis, Indiana
    For high gain, I would suggest the Vishay metal film PR02 line of 2W resistors. They are the same size as a standard 1/2watt carbon film resistor and are excellent in clarity and are not sterile sounding. I have used those in many builds in the preamp section, with excellent results for plate applications.
    JM5010 and neikeel like this.
  8. JM5010
    Nov 11, 2017
    279
    47
    Awesome suggestions!
  9. mickeydg5
    25,059
    12,022
    I like clean so it would most likely be modern design and compound resistors (like @Guitar-Rocker mentioned) and capacitors. I would get my dirt from overdriven tubes and solid state/microprocessor items.
    Dirty people will rather carbon type resistors and old style compound, film and ceramics while driving things into oblivion.
    I cannot exclaim exactly what I would use because I have not don discovery on everything that I might be interested in but I do tend to like CDE (including Orange drop type) and Vishay components.
    JM5010 likes this.
  10. JM5010
    Nov 11, 2017
    279
    47
    Awesome! Time to continue my modding madness.
  11. mickeydg5
    25,059
    12,022
    I am guessing SBE is basically gone falling under Advanced Conversion now and Orange Drop is cancelled by them but maybe picked up by CDE company.
    Everything changes over time. :( :D
