Best preamp tubes?
usablefiber
I know it’s slim pickens with new tube manufacturers today but i’m gonna try to retube the preamp on my yjm, cause even when it’s working it hasn’t sounded very good lol so gonna try that out.
What’s the best set of preamp tubes out there today that aren’t crazy boutique nos prices? i’ve also heard that in the 2nd slot it helps to put a robust tube there.
StrummerJoe
I trust Mesa Boogie branded tubes. They are very strict about testing and what they put their badge on. They get them from all over. What they don't accept a lot of other companies brand with their own logos.
With preamp tubes you can be a lot more flexible as they aren't as likely to blow. I like JJ's and EHX if not using Mesa Boogie. YMMV
Matthews Guitars
Mesa has the strictest tube standards of any branded tube you can buy. I trust their tubes.
That being said, I haven't really had any reason to believe that any of the current brand reissue tubes
you can get today are a whole lot better or worse than any others INCLUDING the high priced vintage/NOS tubes.
So I buy EH, I buy Sovtek, I buy Mullard, I buy JJ, and Ruby, too. Any of them might be better for a specific amp,
and a different one might be better for a different amp.
Yes, I do hear some differences in tube tonality. But more important, there are differences in gain (transconductance),
noise, and susceptibility to microphonics. For the phase inverter I want a strong balanced tube. For a gain stage I
want a low noise tube with plenty of gain. For the cathode follower I make sure that if I use a Russian tube, it can only be a
Sovtek 12AX7WB which is designed for phase inverter usage. JJs are good in phase inverters, being NOT Russian,
and thus NOT having the spiral wound filament that seems to be the key factor in the unacceptability of Russian ECC83/12AX7s
for cathode follower applications.
nickfox
If you've never done so, buy a single NOS Mullard ecc83. You can find decent ones around 100 dollars or so. Just try one and see what it does in the first or second slot of your amp. If you don't think it's worth it, turn around and sell it. But I think you will be impressed.
WellBurnTheSky
If you've never done so, buy a single NOS Mullard ecc83. You can find decent ones around 100 dollars or so. Just try one and see what it does in the first or second slot of your amp. If you don't think it's worth it, turn around and sell it. But I think you will impressed.
Did you manage to grab any here in the EU ? i'm kinda wary of trying Ebay sellers, did you find any reputable seller that has some ?
nickfox
StingRay85
Yeah that's not happening these days bud.
It is... Yesterday I picked up a I63 blackburn, 2 telefunkens, 1 Ei long plate, 1 Heerlen, and 4 7025 tubes for... 75€.
Pete Farrington
Staffordshire UK
Terminology; it matters!
To my thinking, folk seem to use the acronym NOS (new old stock) somewhat inappropriately.
If something has been used for more than a ‘test drive’, then surely it’s no longer ‘new’?
I have 200+ NOS ecc83
What definition of NOS do you use? Tests and looks as new?
StingRay85
For preamp tubes it's almost impossible to see if they are new or not. You can use a digital tester like Maxi Preamp 2, but it also won't tell you if it's new or not. On the other hand is does give a good indication of its performance. The best bet you have is to have the original box with it, only then you can really assume it is NOS/NIB (new in box). And they can still be found. But if you see something on ebay without original box, you already know it's a used tube. People used to buy and have spares with their 60s-70s HIFI sets, and sometimes these spares come up for sale when the person passed away
StingRay85
And sometimes you get lucky. The 7025 are actually Brimar CV4004 box plates new in box (sorry, I'm a tube nerd)
