Best Pre-amp Tubes For My 2061x
Discussion in 'The Workbench' started by Point 2 Point, Apr 8, 2018.
  1. Point 2 Point
    Point 2 Point New Member
    Feb 12, 2011
    23
    16
    San Diego
    What are you using for your preamp 12ax7’s tubes
    Playing a Strat with vintage spec pickups and 2061CX cab with Scumback M75 PVC’s .
    It sounds thin with not enough bottom end.
    I have a Tung Sol 12ax7 in V1 and JJ ECC83s in PI
    Thanks
  2. pedecamp
    15,958
    14,139
    No idea what those speakers sound like, speakers are a big part of your tone. But get rid of that Tungsol in V1 that's a part of the problem. Check your bias too. What guitar/pickups are you using?
    Wow dude you joined in 2011 and this is your first post, how did that happen LOL! A belated welcome to you.
    Georgiatec likes this.
  3. anitoli
    9,058
    11,908
    Go on E-Bay and score some used GE's, RCA's, Phillips, ect that test properly and are priced accordingly and you will hear the difference.
    Georgiatec and neikeel like this.
  4. Metroman
    Metroman Well-Known Member
    Apr 29, 2014
    786
    497
    Look into some GE 12ax7WA. Really hard to beat for the money, and scare the heck out of NOS Mullards.
    I like audiotubes.com, and Tube World, KCA.
  5. jon1917
    jon1917 Active Member
    Feb 20, 2012
    125
    56
    Ireland
    Try a few brands of el84's if you can. This can have a much bigger effect. Do you jumper the channels? If not try a few different combinations for the strat and play with the tone controls on the amp. Finally, how loud do you play it at. Waking up the power valves for these is important (and fun). Have fun.
  6. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,304
    3,498
    Bay Area, CA
    For current production, try the Preferred Series 7025 or the JJ ecc803....Tungsol is the worst sounding preamp tube for Plexi type amp... I found them too glassy and nasally for my liking...
  7. Scumback Speakers
    Sep 16, 2016
    950
    1,398
    Los Angeles, Ca
    Time to get a real Mullard 12AX7 from the 60's in V1, and some other EU tubes in the rest of the sockets. Brimar, Telefunken, Amperex Bugle Boy, etc. I'm going to assume the guitar doesn't have a bad pickup, and there are no pedals involved to thin out the sound.
    Guitar-Rocker likes this.
  8. NewReligion
    NewReligion Well-Known Member Double Platinum Supporting Member VIP Member
    Nov 17, 2009
    11,434
    8,630
    Paradise
    Something Chinese....Russian pre's yuck...♫
  9. eastwood6
    eastwood6 Well-Known Member
    May 27, 2011
    518
    398
    Two things: the 2061cx cab sounds thin at lower volumes regardless of the tubes in the head. It’s the speakers and how they are installed. I’ve had a couple of the 2061cx 2x12 cabs and my 4x10 1965 cabs sounded like a 4x12 in comparison, much bigger at low to mid volumes.
    See, I hear it differently, to me the Russian Electro Harmonix pre amp tubes sound better to me in my non master volume amps - I have both a 2061x and 1974x at the moment. Those are my go-tubes for most Marshall applications. But not the Tungsol reissues. Ick.
  10. Karl Brake
    Karl Brake Member
    Mar 31, 2018
    34
    12
    Slovak tubes, only Slovak, forget China and Russia.
  11. Georgiatec
    Apr 23, 2010
    5,539
    4,979
    In mine, I have vintage Mullard ECC83's in the pre amp and vintage Mazda branded RFT EL84's for the poweramp. ...no thinness at all. The 2061cx could be your problem....they sound best with G12H-30 55htz Greenbacks....the heritage ones, not the Anniversary version that comes factory fitted in the Cab.
    There are so many tonal possibilities using the four inputs on that amp that I would try different combinations of jumpering the inputs before spending cash. You can go from surf to jazz on that amp with variation of input then using volume and tone controls of each channel to taste.
  12. slagg
    slagg Well-Known Member
    Apr 7, 2012
    638
    300
    Cheezeland Wi
    NOS RCA 12ax7a's sound great in my clone
