The post seems a bit contradictory, as the OP says he "loves the sound of the 2205". Well, if he loves the sound of the 2205, why replace it? I took the post as, he wants another Marshall, but an upgrade to the 2205. Since he mentioned he was considering a 2203, I assumed he also likes the tonality of a 2203, as both are fairly bright amps. That's why I went the 2203 route in my suggestion. IMO, the 2203 is a much better sounding amp than a 2205, but doesn't have the level of clipping (distortion) that the 2205 diodes provide. The diode clipping adds some "smoothness", to the tone, much like a good OD pedal. So, aside from the obvious solution of just adding an OD pedal to a 2203, another option is a 2203x with the Hot Mod V2, more gain/overdrive, but all tube. The extra gain from the Hot Mod adds more "smoothness" to the tone, but without the diodes/pedals. I've been using the 2203x/Hot Mod V2 combination, and it's my favorite Marshall of the ones I've owned. So, that was (and is ) my suggestion as an "upgrade" from the 2205. Just one guys opinion, of course. If he's considering amps, other than Marshall's, he should probably change his title, a completely different question.So to answer the original post question then ? Which ‘Marshall ‘ should someone get that ‘ Love’s ‘ the sound of his 2205 and what’s something in the same ballpark .
If it has to be a Marshall then get one of these:
https://marshall.com/marshall-amps/products/amps/origin/origin50h
and do this to it:
or buy a Friedman, a Splawn or some other modern take on a Marshall.
G'day Champions, I have a JCM 800 2205 and a JVM 410H, and would like to acquire another Marshall to my arsenal. I love the sound of the gain channel on the 2205; what would sound similar? I am thinking maybe a 2203 or 2203 reissue, what about the SC20H, does it really sound like a 2203? Maybe even a 900? I am in Australia and don't have a lot of choice available. Open to all options.
Many Thanks.
Nope, doesn't sound like a Jubilee at all.The drive channel of the 2205 has diodes, might be more like a Jubilee.
They are not similar at all. GeezSince you are looking for something “similar” to your 2205, I would suggest a 2204. Both 50 watt Marshalls with similar heritage.![]()
The Hot Mod will work in a SC20 too. But this is the best option, which I concure. Good idea!When I read "replace", I take it as "upgrade". My suggestion would be a 2203 (or 2204), and add a Hot Mod V2. A 2203x (which has an FX loop) is my preference, but depends on whether you need an FX loop. IMO, for a master volume amp, the 2203x "Is" the ultimate Marshall rock & roll machine. The only thing the 2203 lacks (again, IMO) is just a little more gain, which the Hot Mod V2 provides (no mods necessary). The result, is the same (or more) overdrive than the rhythm clip channel of a Jubillee or 2205, and the upper mid voicing of the JCM800. If a 2203 is out of your range, I'd suggest the SC20, which does a very good 20w representation of the 2203. I agree with PelliX statement, regarding diode clipping. While there's nothing wrong with it, I prefer to keep the clipping diodes outside the amp (pedals...).
Doesn't sound similar. It's a darker and more compressed amp. It's great, but sounds completly different than any Marshall.I say Silver Jubilee. It should be pretty easy to find a used 2555X or grab a new one. Or, if you want to collect, get an original.
That's a matter of opinion. Friedmans have less upper midrange than Marshalls. They don't sit as well in a mix. They are great amps but lack the mid focus which cuts through a band mix better than any.The Friedman runt 50 is a Marshall 2205
Only ‘better’ , much ‘better’. Marshall haven’t even got close since unfortunately .
I totally disagree as someone that’s had more than a few Marshall’s and now a Friedman runt 50 . If an amp was lacking in any frequency I would push said frequency up with the eq I all ways have in the loop anyway.That's a matter of opinion. Friedmans have less upper midrange than Marshalls. They don't sit as well in a mix. They are great amps but lack the mid focus which cuts through a band mix better than any.
To me they sound similar, but my ears are not very good.They are not similar at all. Geez
Yes, I originally had a Hot Mod V2 in my SC20H, but I ended up removing it. It didn't suit me as well as it does in the 2203x. The SC20 already sounds dirtier than my 2203x, due to the low operating voltages and having less headroom. David was kind enough to exchange my SC20 Hot Mod for a 2203x version Hot Mod.The Hot Mod will work in a SC20 too. But this is the best option, which I concure. Good idea!
