Best Marshall for Downtuned Death Metal????
Discussion in 'Marshall Amps' started by Shae201, Oct 12, 2021.
  1. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    682
    748
    I'm looking for recommendations for a 2 channel (decent clean). I've thought about the JCM900 4500 DR and a JCM2000 DSL 100. I have a JVM 210H but I've just never jived with the JVM series amps.
  2. SkyMonkey
    3,828
    5,452
    I've sometimes wondered if the speaker you can only get in a 1912 cab or JVM215C might be the perfect down-tuning speaker.
    The Celestion G12B-150 8 ohm has a lower shifted frequency range than the average Celestion.
    For instance, the V-Type, Creamback 75, and V30 all have a range of 70-5000Hz, and resonant frequency of 75Hz.
    The G12B-150 has a range of 60-4000Hz, and a resonant frequency of 77Hz.
    The voice coils are larger too: 2" vs 1.75".
    The problem is sourcing them.
    Mitchell Pearrow and KraftyBob like this.
  3. LCW
    LCW Well-Known Member
    Jan 18, 2017
    454
    888
    Probably not going float your boat, but Valvestate 8100 is a very common death metal amp... Chuck from Death, among others used this...
  4. marshallmellowed
    Jun 26, 2009
    5,180
    8,341
    I'm not a huge DSL fan, but for that type of music it might work pretty well. They have a darker sound, and good low end thump. An EQ in the loop would help also.
  5. anitoli
    10,474
    15,415
    6100 channel 3 gain boost on, mid contour your call......
  6. Shae201
    Dec 20, 2015
    682
    748
    These are great recommendations. I have always been a Marshall loyalist. Honestly one of the best sounding amps I own is an Engl Savage 120 but damnit Marshall is in my DNA. I might pull it on a 900 DR. Trey Azagthoth always used one and had amazing tone.
  7. AdrianDSL
    AdrianDSL Well-Known Member
    Nov 11, 2020
    157
    270
    Melbourne, the place to be. FINED!
    All great suggestions. Also, from my experiments @SkyMonkey is dead on, the choice or speakers / cab and their placement have a huge influence on the tone, so does EQ-ing the amp, or whether or not to use a boost (and which one), EQ pedal in the loop, pickups, guitar, pretty much everything. Apart from the playing style, of course :)
    I own a DSL40CR but sometimes I fancy a JVM or an old JCM800, but then the reality and the budget constraints hit hard and I realize my existing amp, 2x12 cab, speakers and the few OD and EQ pedals I have can get me in the ball park for the tones I like.
  8. LPMarshall hack
    Nov 18, 2009
    11,775
    13,343
    San Diego, CA
  9. Trelwheen
    Trelwheen Unlicensed Rocket Surgeon Double Platinum Supporting Member
    Nov 18, 2017
    3,142
    7,605
    Texas
    Yep. With an MF400 4x12 cab. (G12K100s)
    Kaboom.
    :headbanger:
  10. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,800
    3,327
    Ft.WorthTX
    Valvestate 8100. No contest. Best Marshall for metal ever.
  11. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    460
    775
    A Rat pedal through a 2203 is Death Metal Royalty.
    JCM800 2203 for early Bolt Thrower (tuned to A) and Obituary still uses them on Trevor Perez side but he's not really downtuned that much. Death used 8100 Valvestate. On recordings for recent albums, Carcass blended EVH 5150s with 2203s for the recorded tone. Bands like Electric Wizard used 2203s in the past and I think Pike had some 2203s in his wall of amps in Sleep before they came out with the Rockerverb.
  12. Trelwheen
    Nov 18, 2017
    3,142
    7,605
    Texas
    Citizen's Arrest! Citizen's Arrest!
    There should be a contest!
    Can't be no cheatin' neither, you MFers.....
    VERVEHAMMER and SkyMonkey like this.
  13. pedecamp
    18,383
    19,063
    What is it you dont like about the JVM? A couple hundred bucks to do some mods might be a cheap and easy way to turn it into the amp of your dreams. :yesway:
  14. Shae201
    Dec 20, 2015
    682
    748
    Which ones do you recommend? NF mod? Choke mod? I know there are a few out there.
  15. pedecamp
    18,383
    19,063
    I dont have a JVM but I've read how they can be transformed to another level. Alot of guys have modded JVMs here, post a new thread about modding your JVM and I'm sure those guys will come out of the woodwork with suggestions. How long have you had it and what is it you dont like about your amp?
  16. SkyMonkey
    3,828
    5,452
    Wow. Morbid Angel.
    I had their first two albums on vinyl!!!
    Must go to Spotify. Must go to Spotify!
    Neptical and Shae201 like this.
  17. Benighted
    Benighted Member
    Sep 30, 2020
    74
    76
    Illinois
    Amen to that. Always wanted to emulate the tone of early Obituary (esp. this track):
    Rikamortis, Neptical, Shae201 and 2 others like this.
  18. Totengott666
    Totengott666 Active Member
    Sep 3, 2012
    48
    107
    Nile used DSL heads, doesn't get much more downtuned metal than that, last few years they've used Engls, but for like 15 years it was all DSL
  19. Shae201
    Dec 20, 2015
    682
    748
    The other guitarist in my band is actually taking Skype lessons from Karl Sanders. That guy knows alot of theory and such a versatile guitarist too.
  20. Matthews Guitars
    5,309
    8,060
    If you actually like that stuff....oh well, no accounting for taste! But if you aren't an absolute dyed in the wool brand loyalist, then you should check out a Mesa Badlander.
    That's a lot of money to spend just to chug and play power chords, fourths, fifths, and flatted fifths 99 percent of the time.
    I'm thinking that drop-tuned knothead metal has just about run its course. I hope so, anyway.
    Seventh Son likes this.
