Best Boost Pedal for JCM 800 with no boost?
Discussion in 'The Tone Zone' started by OutsideOctaves, Oct 23, 2020.
  1. OutsideOctaves
    OutsideOctaves New Member
    Oct 23, 2020
    2
    6
    EDIT: Woops, I mixed up the JCM 800 from a previous amp sim with real life, and thought that it had a boost switch on it... memory served me wrong here, because I thought I remembered seeing real ones with a little red/orange switch that said boost on it, but I think it came from previous amp sim(s) I've owned in the past. Seems it was just two jacks in real life, high or low sensitivity. (Unless I'm wrong and there is a type out there irl with a Boost switch)?
    And as far as pedals that I was talking about originally, I was asking more or less about which one would get closest to the "Boost" ciruit. (I kept the original post below, but made the text smaller as there is no strike through here that I can tell)
    Also, I don't own an actual JCM 800 to test against, nor are there any stores nearby with them. Thus, why I came here to ask y'all about the pedal ... oi again I do apologize.
    I've got the STL Amp Hub VST of the JCM 800 but no boost channel on it; what would be the best of the pedals to be closest to the boost option on the JCM 800's that come with boost?
    Pedal options:
    Basic 3 knob compressor
    GEQ 6
    MXN OD808
    BSS SD-1
    IBNZ TS-9
    TCE Preamp
    FRTN 33
    Ignight Amps Tyrant
    XTC BB Preamp
    (Yep, I got the STLAmpHub)
    SkyMonkey and Mitchell Pearrow like this.
  2. 80sTone
    80sTone Active Member
    Nov 10, 2011
    209
    197
    Never used that - but based on the list I like the original SD-1 on the original JCM800 (2204) :) good luck.
    South Park and Mitchell Pearrow like this.
  3. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,767
    1,811
    perpetual house arrest
    :welcome:
    Sorry, I am not quite familiar with the STL Amp Hub, but for a VST I would choose 808, TS-9 or SD-1 from your list (have been the go-to for the JCM800)
  4. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    1,154
    985
    NJ
    I'm not sure I understand the question.
    Maybe check out a Boss BD-2 Blues Driver, you can dial in little, to no, gain, or a bunch, but still retain some picking dynamics. You can crank the volume but minimize gain to use as a boost.
    I don't know.
  5. Mitchell Pearrow
    12,205
    22,090
    :welcome: To the forum
    I like the SD1
    Cheers
    Mitch
  6. DonP
    DonP Active Member
    Jan 28, 2009
    213
    138
    Cincinnati, OH
    Can't you try them and see which one sounds best to you?
  7. scozz
    Jul 20, 2008
    4,139
    9,257
    From your list I’d go with the Maxon od808, but then I’m bias, I like Maxon pedals.
  8. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    1,099
    2,251
    As you can see there are as many preferred pedals as there are players.:lol:
    El Gringo and foofighter like this.
  9. OutsideOctaves
    Oct 23, 2020
    2
    6
    My apologies. I should have (and will edit in) the fact that I don't own an actual JCM 800 to compare it against. Thus why I came here to ask those that may have had them what would be the one that has the closest sound (and thus closest circuit) to the boost circuit... but upon digging into this, I release it's not the 800 that came with the boost, in fact hell none of them do from what I can tell... it was just a switch from channel A to channel B, or in the case of the 800 pluging into low or high sensitivity.
    I was misinformed I guess from previous amp sim software I've owned that had a switch that said boost on it (similar to the lit power switch)... I guess such things happen when you're trying to avoid copyright/trademark infringement... lol. I'm sorry folks for this. We learn stuff sometimes >.> <.< -.-
  10. Marshall Boogie
    Marshall Boogie Well-Known Member
    May 15, 2020
    309
    381
    Watertown, NY USA
    what in the actual heck, quit apologizing. just fyi, plenty of people actually do add a boost switch in place of one of the inputs....there are all sorts of crazy mods for those amps from tube to solid state diodes....sometimes it is best just to assume you remember right and ask your question (and either the ds-1 or a tube screamer will act as a solid state boost...which is what I think you are after)
    El Gringo, scozz and Mitchell Pearrow like this.
  11. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,955
    1,832
    Unfortunately you will need to try them all to really know . Oh , and all the other 10,000 options out there , lol .
    El Gringo, junk notes, scozz and 2 others like this.
  12. SkyMonkey
    2,828
    3,644
    If the difference between the High and Low sensitivity inputs gives you a boost you like, you could try a cheap A/B pedal to switch your guitar signal between the two.
  13. machinated
    machinated Member
    Aug 8, 2019
    26
    39
    I know this isn’t what you’re asking exactly, but I may as well offer my opinion as I’m able to compare. I found the Amp Hub jcm 800 a bit weird compared to my 2203. If you’re looking for absolute accuracy I think it’s a bit of a waste of time here..... just go for what sounds good to you (I know it’s an annoying answer). Their SLO and dual rec sounded really impressive to me, just a couple of the others missed the mark IMO.
    I will say though, that the 2nd amp sim in the Nolly Neural DSP plugin is EXTREMELY similar to my 2203 in sound and behaviour. Right down to all the quirks of the presence and master volume and eq interactions. I really don’t think any other plugins come close to theirs yet.
    Also, yet again I’ll bore on about impedance but it’s really overlooked a lot. Low inputs tend to be lower impedance so while they’re often quieter, they’ll also load the guitar pickups different and therefore sound duller/less crisp than high impedance inputs. to simulate this you could experiment with different DI boxes, and adjust the level going into the plugin. Bear in mind many plugins are calibrated differently and you’ll never really know what they modelled with, so it’s best to just listen and adjust until you’re happy!
    Also, are you possibly thinking of the 2 channel jcm800’s? the 2210 has been modelled by nembrini - for me they’re aren’t on Neural DSP’s level but it may feel more familiar? Most jcm800 plugins are generally going for the vertical input 2203’s in the higher input
  14. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,382
    4,273
    Pennsylvania
    Xotic BB Preamp is my all-time favorite OD pedal.
    Phillip Whitelives likes this.
  15. proxy
    proxy Well-Known Member
    Sep 2, 2010
    695
    331
    Radial Elevator
  16. renips
    renips Well-Known Member
    Nov 15, 2010
    819
    649
    Pembroke Pines, Florida
    Great boost. Bob Bradshaw product. CAE 401
    bullhead likes this.
  17. RobS
    RobS Well-Known Member
    Apr 19, 2009
    992
    278
    Melbourne - Australia
    BOSS GE7, everything flat except level, adjust to suit
    or
    Superdistortion in the bridge
  18. Greg70
    Greg70 Member
    Aug 14, 2020
    45
    38
    Agree on the pickup. I have an old Charvel with active Jackson pickups that will drive my 2203 to full saturation without a pedal.
    dptone5 likes this.
  19. Phillip Whitelives
    Phillip Whitelives New Member
    Jul 9, 2020
    6
    8
    Especially the one with the mid control. I've had it on my board for eight years.
    dptone5 likes this.
  20. NoelH
    NoelH Member
    Aug 31, 2012
    60
    63
    You will get dozens of opinions, every one different. Ask 3 guitar players, and you'll get 6 opinions. Boost pedals are one component in your sound. I personally prefer pedals with asymmetric clipping, but that's me.
    You'll have to play a bunch and find the one that works for you. I have a DS-1 and a 7 band graphic, and a Vox Satchurator. I go into a DSL 50 BTW.
